[GRASS-QA] GRASS QA: hamish | ./grass6/ps/ps.map/do_labels.c |no clones | 2 monsters | 0 warnings
Tue Sep 25 11:59:09 EDT 2007
Hello hamish,
ANALYSIS
ps/ps.map/do_labels.c functions
do_labels (Begins at: 25 Ends at: 80)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
do_label (Begins at: 83 Ends at: 361)
Complexity:   |      52 |   *** | MONSTER |
CalledNBR:    |      59 |     * |         |
LOC:          |     279 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-25 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
