[GRASS-QA] GRASS QA: carlos | ./grass6/imagery/i.his.rgb/openfiles.c |no clones | 0 monsters | 1 warnings
Sun Sep 30 08:15:39 EDT 2007
Hello carlos,
ANALYSIS
imagery/i.his.rgb/openfiles.c functions
openfiles (Begins at: 7 Ends at: 47)
Complexity:   |      13 |       |      OK |
ParamNBR:     |       9 |   *** | MONSTER |
CalledNBR:    |      36 |     * |         |
LOC:          |      41 |       |      OK |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
