[GRASS-QA] GRASS QA: carlos | ./grass6/vector/v.what.rast/main.c |no clones | 2 monsters | 0 warnings
Sun Sep 30 09:02:51 EDT 2007
Hello carlos,
ANALYSIS
vector/v.what.rast/main.c functions
main (Begins at: 41 Ends at: 344)
Complexity:   |      35 |    ** | Warning |
CalledNBR:    |     114 |   *** | MONSTER |
LOC:          |     304 |   *** | MONSTER |
2 metric are OUT OF RANGE!
by_row (Begins at: 347 Ends at: 351)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
by_cat (Begins at: 354 Ends at: 358)
LOC:          |       5 |       |      OK |
metrics are OK
srch_cat (Begins at: 361 Ends at: 369)
Complexity:   |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2007-09-30 are:
                           | quartile  | limit   |
ParamNBR:                2 |         6 |       9 |
CalledNBR:              10 |        60 |      88 |
LOC:                    43 |       195 |     273 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
