[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Dec 10 23:06:03 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.grow/main.c
Function
distance_euclidean_squared(Begins at: 36, Ends at:39)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | |
ParamNBR: | 2 | | OK | |
CalledNBR: | 0 | | OK | |
LOC: | 4 | | OK | |
Conclusion: | this function is a OK |
metrics are OK
distance_euclidian_squared(Begins at: 36, Ends at:39)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
distance_manhattan(Begins at: 46, Ends at:49)
CalledNBR: | 2 | | OK | 2 |
metrics are OK
distance_maximum(Begins at: 41, Ends at:44)
Complexity: | 1 | *** | MONSTER | 1 |
CalledNBR: | 3 | *** | MONSTER | 3 |
LOC: | 4 | *** | MONSTER | 4 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
main(Begins at: 95, Ends at:294)
Complexity: | 29 | | OK | 31 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 70 | | OK | 72 |
LOC: | 200 | | OK | 213 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
setup_neighbors(Begins at: 51, Ends at:76)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 3 | | OK | 3 |
LOC: | 26 | | OK | 26 |
metrics are OK
setup_neighbors_euclidean(Begins at: 78, Ends at:83)
ParamNBR: | 1 | | OK | |
CalledNBR: | 1 | | OK | |
LOC: | 6 | | OK | |
metrics are OK
setup_neighbors_euclidian(Begins at: 78, Ends at:83)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 6 | | OK | 6 |
metrics are OK
setup_neighbors_manhattan(Begins at: 90, Ends at:93)
metrics are OK
setup_neighbors_maximum(Begins at: 85, Ends at:88)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Dec 10 23:32:08 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
