[GRASS-QA] GRASS QA: glynn |ellipse.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 00:31:03 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/proj/ellipse.c
          Function
free_ellps_list(Begins at: 284, Ends at:297)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      14 |       |           OK |        14 |
Conclusion:   | this function is a            OK           |
metrics are OK
get_a_e2_rf(Begins at: 153, Ends at:194)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      42 |     * |      WARNING |        42 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
GPJ_free_ellps(Begins at: 277, Ends at:282)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
GPJ_get_ellipsoid_by_name(Begins at: 131, Ends at:151)
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      21 |       |           OK |        21 |
metrics are OK
GPJ_get_ellipsoid_params(Begins at: 37, Ends at:49)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      13 |       |           OK |        13 |
 at least 1 values are close to an outlier please consider revising code!
GPJ__get_ellipsoid_params(Begins at: 51, Ends at:120)
Complexity:   |      11 |    ** | BABY-MONSTER |        11 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      28 |   *** |      MONSTER |        28 |
LOC:          |      70 |     * |      WARNING |        70 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
read_ellipsoid_table(Begins at: 196, Ends at:275)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      30 |   *** |      MONSTER |        30 |
LOC:          |      80 |    ** | BABY-MONSTER |        80 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 00:57:09 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
