[GRASS-QA] GRASS QA: glynn |copy.c init.c list.c local_proto.h ...| 1
	clones | 0 monsters |0 warnings
    soccerlab.info at gmail.com
    Thu Dec 11 01:16:00 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/general/manage/cmd/copy.c
          Function
main(Begins at: 27, Ends at:99)
              |          New Metrics           |Old Metrics|
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      30 |    ** | BABY-MONSTER |        30 |
LOC:          |      73 |     * |      WARNING |        73 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/general/manage/cmd/init.c
          Function
init(Begins at: 4, Ends at:11)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :grass/trunk/general/manage/cmd/list.c
          Function
main(Begins at: 29, Ends at:109)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |      81 |     * |      WARNING |        81 |
parse(Begins at: 111, Ends at:121)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/general/manage/cmd/list.c clones of parse are:
          /var/project-manager/grass/grassSVN/grass-addons/general/g.xlist/main.c  parse
          File :grass/trunk/general/manage/cmd/local_proto.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/general/manage/cmd/remove.c
          Function
check_reclass(Begins at: 28, Ends at:83)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      56 |     * |      WARNING |        56 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
main(Begins at: 85, Ends at:146)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |      62 |     * |      WARNING |        62 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/general/manage/cmd/rename.c
          Function
main(Begins at: 27, Ends at:145)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      56 |   *** |      MONSTER |        56 |
LOC:          |     119 |    ** | BABY-MONSTER |       119 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 01:42:06 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
