[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 01:36:09 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.grow.distance/main.c
          Function
check(Begins at: 84, Ends at:118)
              |          New Metrics           |Old Metrics|
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      35 |       |           OK |        35 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
distance_euclidean_squared(Begins at: 41, Ends at:44)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
Conclusion:   | this function is a            OK           |
metrics are OK
distance_euclidian_squared(Begins at: 39, Ends at:42)
metrics are OK
distance_manhattan(Begins at: 51, Ends at:54)
CalledNBR:    |       2 |       |           OK |         2 |
metrics are OK
distance_maximum(Begins at: 46, Ends at:49)
Complexity:   |       1 |   *** |      MONSTER |         1 |
CalledNBR:    |       3 |   *** |      MONSTER |         3 |
LOC:          |       4 |   *** |      MONSTER |         4 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
geodesic_distance(Begins at: 56, Ends at:64)
ParamNBR:     |       4 |       |           OK |         4 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |       9 |       |           OK |         9 |
metrics are OK
main(Begins at: 120, Ends at:372)
Complexity:   |      38 |       |           OK |        38 |
CalledNBR:    |     101 |       |           OK |       101 |
LOC:          |     253 |       |           OK |       253 |
metrics are OK
swap_rows(Begins at: 66, Ends at:82)
ParamNBR:     |       1 |     * |      WARNING |         1 |
LOC:          |      17 |       |           OK |        17 |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 02:02:16 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
