[GRASS-QA] GRASS QA: glynn |area.c area_ellipse.c area_poly1.c area_sphere.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 02:11:17 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/gis/area.c
          Function
G_area_of_cell_at_row(Begins at: 91, Ends at:109)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      19 |       |           OK |        19 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_area_of_polygon(Begins at: 165, Ends at:175)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
G_begin_cell_area_calculations(Begins at: 50, Ends at:77)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      28 |       |           OK |        28 |
G_begin_polygon_area_calculations(Begins at: 123, Ends at:140)
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/lib/gis/area_ellipse.c
          Function
G_area_for_zone_on_ellipsoid(Begins at: 96, Ends at:99)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       2 |       |           OK |         2 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
G_begin_zone_area_on_ellipsoid(Begins at: 50, Ends at:56)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |       7 |       |           OK |         7 |
G_darea0_on_ellipsoid(Begins at: 69, Ends at:76)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/gis/area_poly1.c
          Function
G_begin_ellipsoid_polygon_area(Begins at: 67, Ends at:91)
LOC:          |      25 |       |           OK |        25 |
metrics are OK
G_ellipsoid_polygon_area(Begins at: 110, Ends at:158)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      49 |     * |      WARNING |        49 |
 at least 3 values are close to an outlier please consider revising code!
Q(Begins at: 34, Ends at:42)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Qbar(Begins at: 44, Ends at:52)
metrics are OK
Clone analysis:
          File :grass/trunk/lib/gis/area_sphere.c
          Function
G_area_for_zone_on_sphere(Begins at: 78, Ends at:81)
metrics are OK
G_begin_zone_area_on_sphere(Begins at: 42, Ends at:45)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
G_darea0_on_sphere(Begins at: 55, Ends at:58)
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 02:37:24 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
