[GRASS-QA] GRASS QA: martinl |intersect.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 02:51:42 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/vector/Vlib/intersect.c
          Function
add_cross(Begins at: 474, Ends at:498)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      25 |       |           OK |        25 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
cmp_cross(Begins at: 500, Ends at:515)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      16 |       |           OK |        16 |
Conclusion:   | this function is a            OK           |
metrics are OK
cross_seg(Begins at: 545, Ends at:580)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       7 |       |           OK |         7 |
LOC:          |      36 |       |           OK |        36 |
metrics are OK
dist2(Begins at: 517, Ends at:524)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
find_cross(Begins at: 1073, Ends at:1096)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      24 |       |           OK |        24 |
metrics are OK
Vect_line_check_intersection(Begins at: 1110, Ends at:1248)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |     139 |    ** | BABY-MONSTER |       139 |
Vect_line_intersection(Begins at: 600, Ends at:1066)
Complexity:   |      44 |   *** |      MONSTER |        44 |
ParamNBR:     |       7 |    ** | BABY-MONSTER |         7 |
CalledNBR:    |      48 |   *** |      MONSTER |        48 |
LOC:          |     467 |   *** |      MONSTER |       467 |
Conclusion:   | this function is a       MONSTER           |
Vect_segment_intersection(Begins at: 109, Ends at:456)
Complexity:   |      41 |   *** |      MONSTER |        41 |
ParamNBR:     |      19 |   *** |      MONSTER |        19 |
CalledNBR:    |      43 |   *** |      MONSTER |        43 |
LOC:          |     348 |   *** |      MONSTER |       348 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 03:17:49 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
