[GRASS-QA] GRASS QA: martinl |line.cpp vedit.h chtype.c build.c ...|
no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 03:04:17 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/gui/wxpython/vdigit/line.cpp
Class
Digit(Begins at: -9999, Ends at:-9999)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 112 | 402 | 0 | 91 |
|OLD Metrics | 1 | 0 | 112 | 402 | 0 | 91 |
Method
AddLine(Begins at: 38, Ends at:182)
| New Metrics |Old Metrics|
Complexity: | 20 | * | WARNING | 20 |
ParamNBR: | 7 | | OK | 7 |
CalledNBR: | 41 | | OK | 41 |
LOC: | 145 | | OK | 145 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
BreakLines(Begins at: 614, Ends at:651)
Complexity: | 8 | | OK | 8 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 38 | | OK | 38 |
Conclusion: | this function is a OK |
metrics are OK
ConnectLines(Begins at: 681, Ends at:712)
Complexity: | 5 | ** | BABY-MONSTER | 5 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 8 | ** | BABY-MONSTER | 8 |
LOC: | 32 | ** | BABY-MONSTER | 32 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
CopyLines(Begins at: 752, Ends at:807)
Complexity: | 9 | | OK | 9 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 16 | | OK | 16 |
LOC: | 56 | | OK | 56 |
metrics are OK
DeleteLines(Begins at: 338, Ends at:461)
Complexity: | 17 | * | WARNING | 17 |
CalledNBR: | 27 | | OK | 27 |
LOC: | 124 | | OK | 124 |
FlipLines(Begins at: 532, Ends at:560)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 29 | | OK | 29 |
metrics are OK
MergeLines(Begins at: 568, Ends at:604)
ParamNBR: | 0 | * | WARNING | 0 |
LOC: | 37 | | OK | 37 |
MoveLines(Begins at: 475, Ends at:524)
ParamNBR: | 6 | | OK | 6 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 50 | | OK | 50 |
metrics are OK
OpenBackgroundVectorMap(Begins at: 819, Ends at:857)
Complexity: | 6 | ** | BABY-MONSTER | 6 |
ParamNBR: | 1 | ** | BABY-MONSTER | 1 |
CalledNBR: | 14 | *** | MONSTER | 14 |
LOC: | 39 | *** | MONSTER | 39 |
Conclusion: | this function is a MONSTER |
RewriteLine(Begins at: 196, Ends at:283)
Complexity: | 13 | * | WARNING | 13 |
ParamNBR: | 5 | | OK | 5 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 88 | * | WARNING | 88 |
at least 3 values are close to an outlier please consider revising code!
SnapLines(Begins at: 663, Ends at:673)
Complexity: | 2 | * | WARNING | 2 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 11 | * | WARNING | 11 |
SplitLine(Begins at: 296, Ends at:328)
Complexity: | 4 | * | WARNING | 4 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 9 | * | WARNING | 9 |
LOC: | 33 | | OK | 33 |
at least 2 values are close to an outlier please consider revising code!
TypeConvLines(Begins at: 869, Ends at:901)
CalledNBR: | 7 | * | WARNING | 7 |
LOC: | 33 | * | WARNING | 33 |
ZBulkLabeling(Begins at: 728, Ends at:741)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
LOC: | 14 | | OK | 14 |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/include/vedit.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/vector/vedit/chtype.c
Function
Vedit_chtype_lines(Begins at: 36, Ends at:97)
Complexity: | 12 | * | WARNING | 12 |
LOC: | 62 | * | WARNING | 62 |
Clone analysis:
File :grass/trunk/lib/vector/Vlib/build.c
Function
format(Begins at: 29, Ends at:33)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 5 | | OK | 5 |
metrics are OK
prnmsg(Begins at: 48, Ends at:62)
LOC: | 15 | | OK | 15 |
metrics are OK
Vect_build(Begins at: 73, Ends at:76)
LOC: | 4 | | OK | 4 |
metrics are OK
Vect_build_partial(Begins at: 128, Ends at:248)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 46 | *** | MONSTER | 46 |
LOC: | 121 | ** | BABY-MONSTER | 121 |
Vect_get_built(Begins at: 86, Ends at:89)
CalledNBR: | 0 | | OK | 0 |
metrics are OK
Vect_save_spatial_index(Begins at: 408, Ends at:440)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 14 | * | WARNING | 14 |
Vect_save_topo(Begins at: 257, Ends at:289)
Vect_spatial_index_dump(Begins at: 451, Ends at:462)
CalledNBR: | 3 | | OK | 3 |
LOC: | 12 | | OK | 12 |
metrics are OK
Vect_topo_dump(Begins at: 300, Ends at:398)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 99 | ** | BABY-MONSTER | 99 |
Clone analysis:
File :grass/trunk/vector/v.edit/main.c
Function
main(Begins at: 23, Ends at:471)
Complexity: | 75 | *** | MONSTER | 75 |
CalledNBR: | 184 | *** | MONSTER | 184 |
LOC: | 449 | *** | MONSTER | 449 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 03:30:24 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
