[GRASS-QA] GRASS QA: neteler |data_types.h defs.h edge.c edge.h ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 04:38:52 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/vector/v.delaunay2/data_types.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/vector/v.delaunay2/defs.h
          File :grass/branches/develbranch_6/vector/v.delaunay2/edge.c
          File :grass/branches/develbranch_6/vector/v.delaunay2/edge.h
          File :grass/branches/develbranch_6/vector/v.delaunay2/geometry.c
          File :grass/branches/develbranch_6/vector/v.delaunay2/geometry.h
          File :grass/branches/develbranch_6/vector/v.delaunay2/geom_primitives.h
          File :grass/branches/develbranch_6/vector/v.delaunay2/in_out.c
          File :grass/branches/develbranch_6/vector/v.delaunay2/in_out.h
          File :grass/branches/develbranch_6/vector/v.delaunay2/main.c
          File :grass/branches/develbranch_6/vector/v.delaunay2/memory.c
          File :grass/branches/develbranch_6/vector/v.delaunay2/memory.h
____________________________________________
Threshold grass key metrics values at Thu Dec 11 05:05:01 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
