[GRASS-QA] GRASS QA: glynn |columns.c connect.c copy.c createdb.c
...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 05:10:00 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/db/db.columns/columns.c
Function
main(Begins at: 33, Ends at:66)
| New Metrics |Old Metrics|
Complexity: | 5 | | OK | |
ParamNBR: | 2 | | OK | |
CalledNBR: | 19 | * | WARNING | |
LOC: | 34 | | OK | |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
parse_command_line(Begins at: 69, Ends at:101)
Complexity: | 4 | | OK | |
CalledNBR: | 12 | * | WARNING | |
LOC: | 33 | | OK | |
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/db/db.connect/connect.c
Function
main(Begins at: 30, Ends at:174)
Complexity: | 12 | * | WARNING | |
CalledNBR: | 39 | *** | MONSTER | |
LOC: | 145 | *** | MONSTER | |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
File :grass/trunk/db/db.copy/copy.c
Function
main(Begins at: 23, Ends at:129)
CalledNBR: | 41 | *** | MONSTER | |
LOC: | 107 | ** | BABY-MONSTER | |
Clone analysis:
File :grass/trunk/db/db.createdb/createdb.c
Function
main(Begins at: 33, Ends at:51)
Complexity: | 2 | | OK | |
CalledNBR: | 8 | | OK | |
LOC: | 19 | | OK | |
Conclusion: | this function is a OK |
metrics are OK
parse_command_line(Begins at: 54, Ends at:79)
CalledNBR: | 9 | | OK | |
LOC: | 26 | | OK | |
metrics are OK
Clone analysis:
File :grass/trunk/db/db.databases/databases.c
Function
main(Begins at: 34, Ends at:66)
CalledNBR: | 14 | * | WARNING | |
parse_command_line(Begins at: 69, Ends at:99)
CalledNBR: | 10 | * | WARNING | |
LOC: | 31 | | OK | |
Clone analysis:
File :grass/trunk/db/db.describe/describe.c
Function
main(Begins at: 38, Ends at:89)
Complexity: | 6 | * | WARNING | |
CalledNBR: | 32 | ** | BABY-MONSTER | |
LOC: | 52 | * | WARNING | |
Conclusion: | this function is a BABY-MONSTER |
parse_command_line(Begins at: 92, Ends at:135)
CalledNBR: | 16 | * | WARNING | |
LOC: | 44 | * | WARNING | |
at least 2 values are close to an outlier please consider revising code!
Clone analysis:
File :grass/trunk/db/db.describe/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/db/db.describe/printtab.c
Function
print_column_definition(Begins at: 35, Ends at:59)
ParamNBR: | 1 | | OK | |
CalledNBR: | 24 | ** | BABY-MONSTER | |
LOC: | 25 | | OK | |
print_priv(Begins at: 61, Ends at:78)
CalledNBR: | 5 | | OK | |
LOC: | 18 | | OK | |
metrics are OK
print_table_definition(Begins at: 6, Ends at:33)
LOC: | 28 | | OK | |
Clone analysis:
File :grass/trunk/db/db.drivers/drivers.c
Function
main(Begins at: 33, Ends at:53)
LOC: | 21 | | OK | |
metrics are OK
parse_command_line(Begins at: 56, Ends at:81)
Clone analysis:
File :grass/trunk/db/db.dropdb/dropdb.c
Function
metrics are OK
metrics are OK
Clone analysis:
File :grass/trunk/db/db.droptable/droptable.c
Function
main(Begins at: 33, Ends at:57)
Complexity: | 3 | | OK | |
CalledNBR: | 11 | * | WARNING | |
parse_command_line(Begins at: 60, Ends at:87)
Clone analysis:
File :grass/trunk/db/db.execute/execute.c
Function
get_stmt(Begins at: 136, Ends at:168)
main(Begins at: 37, Ends at:91)
Complexity: | 9 | * | WARNING | |
CalledNBR: | 25 | ** | BABY-MONSTER | |
LOC: | 55 | * | WARNING | |
parse_command_line(Begins at: 94, Ends at:133)
CalledNBR: | 15 | * | WARNING | |
LOC: | 40 | | OK | |
stmt_is_empty(Begins at: 171, Ends at:176)
Complexity: | 1 | | OK | |
CalledNBR: | 2 | | OK | |
LOC: | 6 | | OK | |
metrics are OK
Clone analysis:
File :grass/trunk/db/db.select/local_proto.h
File :grass/trunk/db/db.select/printtab.c
Function
metrics are OK
Clone analysis:
File :grass/trunk/db/db.select/select.c
Function
get_stmt(Begins at: 269, Ends at:288)
CalledNBR: | 4 | | OK | |
LOC: | 20 | | OK | |
metrics are OK
main(Begins at: 38, Ends at:91)
LOC: | 54 | * | WARNING | |
parse_command_line(Begins at: 165, Ends at:266)
Complexity: | 8 | * | WARNING | |
CalledNBR: | 38 | *** | MONSTER | |
LOC: | 102 | ** | BABY-MONSTER | |
sel(Begins at: 94, Ends at:162)
Complexity: | 18 | ** | BABY-MONSTER | |
LOC: | 69 | * | WARNING | |
stmt_is_empty(Begins at: 291, Ends at:296)
LOC: | 6 | | OK | |
metrics are OK
Clone analysis:
File :grass/trunk/db/db.tables/tables.c
Function
main(Begins at: 34, Ends at:63)
LOC: | 30 | | OK | |
parse_command_line(Begins at: 66, Ends at:104)
LOC: | 39 | | OK | |
Clone analysis:
File :grass/trunk/general/g.copy/copy.c
File :grass/trunk/general/g.copy/main.c
File :grass/trunk/general/g.list/list.c
File :grass/trunk/general/g.list/main.c
File :grass/trunk/general/g.remove/main.c
File :grass/trunk/general/g.remove/remove.c
File :grass/trunk/general/g.rename/main.c
File :grass/trunk/general/g.rename/rename.c
File :grass/trunk/raster/r.ros/local_proto.h
File :grass/trunk/raster/r.ros/main.c
File :grass/trunk/raster/r.ros/spot_dist.c
File :grass/trunk/raster/r.spread/cell_ptrHa.h
File :grass/trunk/raster/r.spread/cmd_line.h
File :grass/trunk/raster/r.spread/collect_ori.c
File :grass/trunk/raster/r.spread/costHa.h
File :grass/trunk/raster/r.spread/deleteHa.c
File :grass/trunk/raster/r.spread/display.c
File :grass/trunk/raster/r.spread/fixHa.c
File :grass/trunk/raster/r.spread/get_minHa.c
File :grass/trunk/raster/r.spread/insert2Ha.c
File :grass/trunk/raster/r.spread/insertHa.c
File :grass/trunk/raster/r.spread/local_proto.h
File :grass/trunk/raster/r.spread/main.c
File :grass/trunk/raster/r.spread/pick_dist.c
File :grass/trunk/raster/r.spread/pick_ignite.c
File :grass/trunk/raster/r.spread/ram2out.c
File :grass/trunk/raster/r.spread/replaceHa.c
File :grass/trunk/raster/r.spread/select_linksB.c
File :grass/trunk/raster/r.spread/spot.c
File :grass/trunk/raster/r.spread/spread.c
File :grass/trunk/raster/r.spreadpath/drawline.c
File :grass/trunk/raster/r.spreadpath/insert.c
File :grass/trunk/raster/r.spreadpath/local_proto.h
File :grass/trunk/raster/r.spreadpath/main.c
File :grass/trunk/raster/r.spreadpath/path_finder.c
File :grass/trunk/raster/r.spreadpath/point.h
File :grass/trunk/raster/r.spreadpath/stash.h
File :grass/trunk/raster3d/base/r3.info.main.c
Function
format_double(Begins at: 428, Ends at:434)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 7 | | OK | 7 |
metrics are OK
main(Begins at: 46, Ends at:425)
Complexity: | 49 | *** | MONSTER | 49 |
CalledNBR: | 183 | *** | MONSTER | 183 |
LOC: | 380 | *** | MONSTER | 380 |
Clone analysis:
File :grass/trunk/raster3d/base/r3.timestamp.main.c
Function
main(Begins at: 31, Ends at:95)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 24 | ** | BABY-MONSTER | 24 |
LOC: | 65 | * | WARNING | 65 |
Clone analysis:
File :grass/trunk/raster3d/r3.info/r3.info.main.c
Function
format_double(Begins at: 432, Ends at:438)
LOC: | 7 | | OK | |
metrics are OK
main(Begins at: 46, Ends at:429)
Complexity: | 49 | *** | MONSTER | |
CalledNBR: | 187 | *** | MONSTER | |
LOC: | 384 | *** | MONSTER | |
Clone analysis:
File :grass/trunk/raster3d/r3.timestamp/r3.timestamp.main.c
Function
Complexity: | 7 | * | WARNING | |
LOC: | 65 | * | WARNING | |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 05:36:08 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
