[GRASS-QA] GRASS QA: neteler |main.c close_maps.c close_maps2.c
def_basin.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 05:46:15 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.watershed2/front/main.c
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/raster/r.watershed2/ram/close_maps.c
File :grass/trunk/raster/r.watershed2/ram/close_maps2.c
File :grass/trunk/raster/r.watershed2/ram/def_basin.c
File :grass/trunk/raster/r.watershed2/ram/do_astar.c
File :grass/trunk/raster/r.watershed2/ram/do_astar.h
File :grass/trunk/raster/r.watershed2/ram/do_cum.c
File :grass/trunk/raster/r.watershed2/ram/find_pour.c
File :grass/trunk/raster/r.watershed2/ram/flag.h
File :grass/trunk/raster/r.watershed2/ram/flag_clr_all.c
File :grass/trunk/raster/r.watershed2/ram/flag_create.c
File :grass/trunk/raster/r.watershed2/ram/flag_destroy.c
File :grass/trunk/raster/r.watershed2/ram/flag_get.c
File :grass/trunk/raster/r.watershed2/ram/flag_set.c
File :grass/trunk/raster/r.watershed2/ram/flag_unset.c
File :grass/trunk/raster/r.watershed2/ram/Gwater.h
File :grass/trunk/raster/r.watershed2/ram/haf_side.c
File :grass/trunk/raster/r.watershed2/ram/init_vars.c
File :grass/trunk/raster/r.watershed2/ram/main.c
File :grass/trunk/raster/r.watershed2/ram/no_stream.c
File :grass/trunk/raster/r.watershed2/ram/over_cells.c
File :grass/trunk/raster/r.watershed2/ram/ramseg.c
File :grass/trunk/raster/r.watershed2/ram/ramseg.h
File :grass/trunk/raster/r.watershed2/ram/sg_factor.c
File :grass/trunk/raster/r.watershed2/ram/slope_len.c
File :grass/trunk/raster/r.watershed2/ram/split_str.c
File :grass/trunk/raster/r.watershed2/ram/usage.c
File :grass/trunk/raster/r.watershed2/seg/bseg_close.c
File :grass/trunk/raster/r.watershed2/seg/bseg_get.c
File :grass/trunk/raster/r.watershed2/seg/bseg_open.c
File :grass/trunk/raster/r.watershed2/seg/bseg_put.c
File :grass/trunk/raster/r.watershed2/seg/bseg_read.c
File :grass/trunk/raster/r.watershed2/seg/bseg_write.c
File :grass/trunk/raster/r.watershed2/seg/close_maps.c
File :grass/trunk/raster/r.watershed2/seg/close_maps2.c
File :grass/trunk/raster/r.watershed2/seg/cseg.h
File :grass/trunk/raster/r.watershed2/seg/cseg_close.c
File :grass/trunk/raster/r.watershed2/seg/cseg_get.c
File :grass/trunk/raster/r.watershed2/seg/cseg_open.c
File :grass/trunk/raster/r.watershed2/seg/cseg_put.c
File :grass/trunk/raster/r.watershed2/seg/cseg_read.c
File :grass/trunk/raster/r.watershed2/seg/cseg_write.c
File :grass/trunk/raster/r.watershed2/seg/def_basin.c
File :grass/trunk/raster/r.watershed2/seg/do_astar.c
File :grass/trunk/raster/r.watershed2/seg/do_astar.h
File :grass/trunk/raster/r.watershed2/seg/do_cum.c
File :grass/trunk/raster/r.watershed2/seg/dseg_close.c
File :grass/trunk/raster/r.watershed2/seg/dseg_get.c
File :grass/trunk/raster/r.watershed2/seg/dseg_open.c
File :grass/trunk/raster/r.watershed2/seg/dseg_put.c
File :grass/trunk/raster/r.watershed2/seg/dseg_read.c
File :grass/trunk/raster/r.watershed2/seg/dseg_write.c
File :grass/trunk/raster/r.watershed2/seg/find_pour.c
File :grass/trunk/raster/r.watershed2/seg/Gwater.h
File :grass/trunk/raster/r.watershed2/seg/haf_side.c
File :grass/trunk/raster/r.watershed2/seg/init_vars.c
File :grass/trunk/raster/r.watershed2/seg/main.c
File :grass/trunk/raster/r.watershed2/seg/no_stream.c
File :grass/trunk/raster/r.watershed2/seg/over_cells.c
File :grass/trunk/raster/r.watershed2/seg/sg_factor.c
File :grass/trunk/raster/r.watershed2/seg/slope_len.c
File :grass/trunk/raster/r.watershed2/seg/split_str.c
File :grass/trunk/raster/r.watershed2/seg/sseg_close.c
File :grass/trunk/raster/r.watershed2/seg/sseg_get.c
File :grass/trunk/raster/r.watershed2/seg/sseg_open.c
File :grass/trunk/raster/r.watershed2/seg/sseg_put.c
File :grass/trunk/raster/r.watershed2/seg/usage.c
File :grass/trunk/raster/r.watershed2/shed/accum_down.c
File :grass/trunk/raster/r.watershed2/shed/basin_maps.c
File :grass/trunk/raster/r.watershed2/shed/com_line.c
File :grass/trunk/raster/r.watershed2/shed/file_in.c
File :grass/trunk/raster/r.watershed2/shed/free.c
File :grass/trunk/raster/r.watershed2/shed/insert_cat.c
File :grass/trunk/raster/r.watershed2/shed/intro.c
File :grass/trunk/raster/r.watershed2/shed/main.c
File :grass/trunk/raster/r.watershed2/shed/print.c
File :grass/trunk/raster/r.watershed2/shed/read.c
File :grass/trunk/raster/r.watershed2/shed/valid.c
File :grass/trunk/raster/r.watershed2/shed/watershed.h
____________________________________________
Threshold grass key metrics values at Thu Dec 11 06:12:24 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
