[GRASS-QA] GRASS QA: marisn |map.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Dec 11 06:21:39 EST 2008
Hello marisn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/vector/Vlib/map.c
Function
copy_file(Begins at: 110, Ends at:141)
| New Metrics |Old Metrics|
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 32 | | OK | 32 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Vect_copy(Begins at: 156, Ends at:278)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 57 | *** | MONSTER | 57 |
LOC: | 123 | ** | BABY-MONSTER | 123 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Vect_copy_map_lines(Begins at: 44, Ends at:99)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 56 | * | WARNING | 56 |
at least 3 values are close to an outlier please consider revising code!
Vect_copy_table(Begins at: 642, Ends at:648)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a BABY-MONSTER |
Vect_copy_tables(Begins at: 564, Ends at:627)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 22 | * | WARNING | 22 |
LOC: | 64 | * | WARNING | 64 |
at least 4 values are close to an outlier please consider revising code!
Vect_copy_table_by_cats(Begins at: 665, Ends at:718)
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 54 | * | WARNING | 54 |
Vect_delete(Begins at: 424, Ends at:550)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 62 | *** | MONSTER | 62 |
LOC: | 127 | ** | BABY-MONSTER | 127 |
Vect_rename(Begins at: 295, Ends at:414)
CalledNBR: | 50 | *** | MONSTER | 50 |
LOC: | 120 | ** | BABY-MONSTER | 120 |
Vect_set_category_index_update(Begins at: 744, Ends at:747)
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
Conclusion: | this function is a OK |
metrics are OK
Vect_set_release_support(Begins at: 729, Ends at:732)
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 06:47:48 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
