[GRASS-QA] GRASS QA: martinl |Vect.h buffer.c buffer2.c dgraph.c ...|
1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 06:30:37 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/include/Vect.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/vector/Vlib/buffer.c
Function
clean_parallel(Begins at: 132, Ends at:262)
| New Metrics |Old Metrics|
Complexity: | 21 | *** | MONSTER | 21 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 131 | ** | BABY-MONSTER | 131 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
find_cross(Begins at: 53, Ends at:91)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 39 | | OK | 39 |
Conclusion: | this function is a BABY-MONSTER |
parallel_line(Begins at: 271, Ends at:340)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 70 | * | WARNING | 70 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
point_in_buf(Begins at: 97, Ends at:115)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 19 | | OK | 19 |
at least 1 values are close to an outlier please consider revising code!
vect(Begins at: 29, Ends at:44)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
LOC: | 16 | | OK | 16 |
Vect_line_buffer(Begins at: 379, Ends at:481)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 103 | ** | BABY-MONSTER | 103 |
Vect_line_parallel(Begins at: 353, Ends at:366)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 14 | | OK | 14 |
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/buffer.c clones of vect are:
/var/project-manager/grass/grassSVN/grass-addons/vector/v.parallel2/vlib_buffer.c norm_vector
File :grass/trunk/lib/vector/Vlib/buffer2.c
File :grass/trunk/lib/vector/Vlib/dgraph.c
File :grass/trunk/lib/vector/Vlib/dgraph.h
File :grass/trunk/lib/vector/Vlib/e_intersect.c
File :grass/trunk/lib/vector/Vlib/e_intersect.h
File :grass/trunk/vector/v.buffer2/dgraph.c
File :grass/trunk/vector/v.buffer2/dgraph.h
File :grass/trunk/vector/v.buffer2/e_intersect.c
File :grass/trunk/vector/v.buffer2/e_intersect.h
File :grass/trunk/vector/v.buffer2/vlib_buffer.c
File :grass/trunk/vector/v.parallel2/dgraph.c
File :grass/trunk/vector/v.parallel2/dgraph.h
File :grass/trunk/vector/v.parallel2/e_intersect.c
File :grass/trunk/vector/v.parallel2/e_intersect.h
File :grass/trunk/vector/v.parallel2/vlib_buffer.c
____________________________________________
Threshold grass key metrics values at Thu Dec 11 06:56:46 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
