[GRASS-QA] GRASS QA: martinl |main.c main.c main.c main.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 08:02:36 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/display/d.rast/main.c
          Function
main(Begins at: 35, Ends at:137)
              |          New Metrics           |Old Metrics|
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       2 |     * |      WARNING |         2 |
CalledNBR:    |      36 |     * |      WARNING |        36 |
LOC:          |     103 |       |           OK |       103 |
Conclusion:   | this function is a       WARNING           |
 at least 3 values are close to an outlier please consider revising code!
parse_catlist(Begins at: 139, Ends at:169)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |       9 |     * |      WARNING |         9 |
LOC:          |      31 |       |           OK |        31 |
parse_d_mask_rule(Begins at: 234, Ends at:263)
Complexity:   |       6 |     * |      WARNING |         6 |
ParamNBR:     |       3 |       |           OK |         3 |
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      30 |       |           OK |        30 |
 at least 1 values are close to an outlier please consider revising code!
parse_mask_rule(Begins at: 203, Ends at:232)
parse_vallist(Begins at: 171, Ends at:201)
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       9 |    ** | BABY-MONSTER |         9 |
LOC:          |      31 |    ** | BABY-MONSTER |        31 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/display/d.thematic.area/main.c
          Function
main(Begins at: 33, Ends at:536)
Complexity:   |      51 |   *** |      MONSTER |        51 |
CalledNBR:    |     164 |   *** |      MONSTER |       164 |
LOC:          |     504 |   *** |      MONSTER |       504 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
          File :grass/trunk/display/d.vect/main.c
          Function
icon_files(Begins at: 32, Ends at:76)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      45 |     * |      WARNING |        45 |
main(Begins at: 78, Ends at:720)
Complexity:   |      80 |   *** |      MONSTER |        80 |
CalledNBR:    |     202 |   *** |      MONSTER |       202 |
LOC:          |     643 |   *** |      MONSTER |       643 |
Clone analysis:
          File :grass/trunk/vector/v.category/main.c
          Function
main(Begins at: 48, Ends at:501)
Complexity:   |      84 |   *** |      MONSTER |        84 |
CalledNBR:    |     122 |   *** |      MONSTER |       122 |
LOC:          |     454 |   *** |      MONSTER |       454 |
Clone analysis:
          File :grass/trunk/vector/v.edit/args.c
          Function
parser(Begins at: 33, Ends at:360)
Complexity:   |      33 |   *** |      MONSTER |        33 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      94 |   *** |      MONSTER |        94 |
LOC:          |     328 |   *** |      MONSTER |       328 |
Clone analysis:
          File :grass/trunk/vector/v.extract/main.c
          Function
add_cat(Begins at: 38, Ends at:48)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
main(Begins at: 50, Ends at:413)
Complexity:   |      52 |   *** |      MONSTER |        52 |
CalledNBR:    |     135 |   *** |      MONSTER |       135 |
LOC:          |     364 |   *** |      MONSTER |       364 |
scan_cats(Begins at: 417, Ends at:436)
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
LOC:          |      20 |       |           OK |        20 |
Clone analysis:
          File :grass/trunk/vector/v.in.ogr/main.c
          Function
main(Begins at: 47, Ends at:1133)
Complexity:   |     115 |   *** |      MONSTER |       115 |
CalledNBR:    |     422 |   *** |      MONSTER |       422 |
LOC:          |    1087 |   *** |      MONSTER |      1087 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 08:28:46 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
