[GRASS-QA] GRASS QA: martinl |cats.c main.c | no clones | 0 monsters
|0 warnings
soccerlab.info at gmail.com
Thu Dec 11 08:17:35 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/vector/vedit/cats.c
Function
Vedit_modify_cats(Begins at: 32, Ends at:101)
| New Metrics |Old Metrics|
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 70 | * | WARNING | 70 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/vector/v.edit/main.c
Function
main(Begins at: 23, Ends at:475)
Complexity: | 75 | *** | MONSTER | 75 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 184 | *** | MONSTER | 184 |
LOC: | 453 | *** | MONSTER | 453 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 08:43:45 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
