[GRASS-QA] GRASS QA: martinl |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Dec 11 08:27:37 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/vector/v.extract/main.c
Function
add_cat(Begins at: 38, Ends at:48)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
main(Begins at: 50, Ends at:415)
Complexity: | 52 | *** | MONSTER | 52 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 135 | *** | MONSTER | 135 |
LOC: | 366 | *** | MONSTER | 366 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
scan_cats(Begins at: 419, Ends at:438)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 20 | | OK | 20 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 08:53:47 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
