[GRASS-QA] GRASS QA: glynn |locale.c mach_name.c spawn.c | no clones
| 0 monsters |0 warnings
soccerlab.info at gmail.com
Thu Dec 11 08:32:43 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/gis/locale.c
Function
G_gettext(Begins at: 53, Ends at:74)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 22 | | OK | 22 |
Conclusion: | this function is a OK |
metrics are OK
locale_dir(Begins at: 25, Ends at:41)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 17 | | OK | 17 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/gis/mach_name.c
Function
G__machine_name(Begins at: 23, Ends at:40)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 18 | | OK | 18 |
metrics are OK
Clone analysis:
File :grass/trunk/lib/gis/spawn.c
Class
binding(Begins at: 188, Ends at:192)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Class
redirect(Begins at: 168, Ends at:174)
Class
signal(Begins at: 176, Ends at:186)
Function
begin_spawn(Begins at: 451, Ends at:459)
CalledNBR: | 0 | | OK | 0 |
LOC: | 9 | | OK | 9 |
metrics are OK
do_bindings(Begins at: 214, Ends at:222)
Complexity: | 2 | * | WARNING | 2 |
ParamNBR: | 3 | | OK | 3 |
CalledNBR: | 1 | * | WARNING | 1 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
do_bindings(Begins at: 377, Ends at:389)
ParamNBR: | 2 | * | WARNING | 3 |
CalledNBR: | 5 | * | WARNING | 1 |
LOC: | 13 | * | WARNING | 9 |
at least 4 values are close to an outlier please consider revising code!
do_redirects(Begins at: 342, Ends at:375)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 14 | ** | BABY-MONSTER | 14 |
LOC: | 34 | * | WARNING | 34 |
Conclusion: | this function is a BABY-MONSTER |
metric are OUT OF RANGE!
do_signals(Begins at: 281, Ends at:340)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 17 | ** | BABY-MONSTER | 17 |
LOC: | 60 | * | WARNING | 60 |
do_spawn(Begins at: 391, Ends at:447)
Complexity: | 10 | | OK | 10 |
CalledNBR: | 23 | | OK | 23 |
LOC: | 57 | | OK | 57 |
metrics are OK
G_spawn(Begins at: 89, Ends at:164)
CalledNBR: | 24 | | OK | 24 |
LOC: | 76 | | OK | 76 |
metrics are OK
G_spawn_ex(Begins at: 640, Ends at:651)
Complexity: | 1 | ** | BABY-MONSTER | 1 |
CalledNBR: | 5 | * | WARNING | 5 |
LOC: | 12 | * | WARNING | 12 |
G_vspawn_ex(Begins at: 621, Ends at:628)
CalledNBR: | 3 | * | WARNING | 3 |
LOC: | 8 | * | WARNING | 8 |
parse_arglist(Begins at: 537, Ends at:609)
Complexity: | 15 | * | WARNING | 15 |
ParamNBR: | 1 | * | WARNING | 1 |
CalledNBR: | 17 | | OK | 17 |
LOC: | 73 | | OK | 73 |
parse_argvec(Begins at: 463, Ends at:535)
Complexity: | 15 | | OK | 15 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 08:58:54 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
