[GRASS-QA] GRASS QA: glynn |Polygon.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Dec 11 08:59:07 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/driver/Polygon.c
Class
point(Begins at: 6, Ends at:9)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
cmp_int(Begins at: 11, Ends at:17)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a OK |
metrics are OK
COM_Polygon_abs(Begins at: 122, Ends at:130)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 9 | | OK | 9 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
COM_Polygon_rel(Begins at: 132, Ends at:158)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 27 | | OK | 27 |
fill(Begins at: 19, Ends at:22)
LOC: | 4 | | OK | 4 |
fill_polygon(Begins at: 100, Ends at:120)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 21 | | OK | 21 |
line(Begins at: 24, Ends at:67)
Complexity: | 8 | * | WARNING | 8 |
LOC: | 44 | * | WARNING | 44 |
at least 3 values are close to an outlier please consider revising code!
poly(Begins at: 69, Ends at:98)
Complexity: | 9 | * | WARNING | 9 |
LOC: | 30 | | OK | 30 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 09:25:18 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
