[GRASS-QA] GRASS QA: martinl |frac.h main.c open_files.c process.c ...| no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 10:05:37 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.surf.fractal/frac.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/raster/r.surf.fractal/main.c
          Function
main(Begins at: 28, Ends at:86)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      59 |     * |      WARNING |        61 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.surf.fractal/open_files.c
          Function
open_files(Begins at: 19, Ends at:28)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.surf.fractal/process.c
          Function
data_reset(Begins at: 77, Ends at:86)
CalledNBR:    |       0 |       |           OK |         0 |
metrics are OK
process(Begins at: 21, Ends at:70)
Complexity:   |       2 |       |           OK |         1 |
CalledNBR:    |      14 |     * |      WARNING |        11 |
LOC:          |      50 |     * |      WARNING |        46 |
Clone analysis:
          File :grass/trunk/raster/r.surf.fractal/spec_syn.c
          Function
specsyn(Begins at: 31, Ends at:166)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      29 |    ** | BABY-MONSTER |        29 |
LOC:          |     136 |    ** | BABY-MONSTER |       136 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :grass/trunk/raster/r.surf.fractal/write_rast.c
          Function
write_rast(Begins at: 20, Ends at:80)
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      13 |     * |      WARNING |        13 |
LOC:          |      61 |     * |      WARNING |        60 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 10:31:48 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
