[GRASS-QA] GRASS QA: martinl |cont.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Dec 11 10:23:07 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.contour/cont.c
          Class
cell(Begins at: 34, Ends at:39)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
checkedge(Begins at: 385, Ends at:391)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       7 |       |           OK |         7 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
contour(Begins at: 49, Ends at:216)
Complexity:   |      26 |   *** |      MONSTER |        26 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      46 |   *** |      MONSTER |        46 |
LOC:          |     168 |   *** |      MONSTER |       168 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
findcrossing(Begins at: 272, Ends at:327)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      56 |     * |      WARNING |        56 |
 at least 3 values are close to an outlier please consider revising code!
getnewcell(Begins at: 224, Ends at:237)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      14 |       |           OK |        14 |
getpoint(Begins at: 333, Ends at:379)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      47 |     * |      WARNING |        47 |
newedge(Begins at: 242, Ends at:264)
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      23 |       |           OK |        23 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Thu Dec 11 10:49:19 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
