[GRASS-QA] GRASS QA: martinl |areas.c find.c global.h lines.c ...| no
	clones | 0 monsters |0 warnings
    soccerlab.info at gmail.com
    Thu Dec 11 11:09:26 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/vector/v.to.db/areas.c
          Function
read_areas(Begins at: 15, Ends at:78)
              |          New Metrics           |Old Metrics|
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      64 |     * |      WARNING |        64 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
          File :grass/branches/develbranch_6/vector/v.to.db/find.c
          Function
find_cat(Begins at: 6, Ends at:28)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      23 |       |           OK |        23 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :grass/branches/develbranch_6/vector/v.to.db/global.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/branches/develbranch_6/vector/v.to.db/lines.c
          Function
read_lines(Begins at: 57, Ends at:271)
Complexity:   |      35 |   *** |      MONSTER |        35 |
CalledNBR:    |      54 |   *** |      MONSTER |        54 |
LOC:          |     215 |   *** |      MONSTER |       215 |
Conclusion:   | this function is a       MONSTER           |
read_side_cats(Begins at: 10, Ends at:50)
Complexity:   |       9 |     * |      WARNING |         9 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      41 |       |           OK |        41 |
Conclusion:   | this function is a       WARNING           |
 at least 2 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/branches/develbranch_6/vector/v.to.db/main.c
          Function
main(Begins at: 22, Ends at:98)
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      29 |    ** | BABY-MONSTER |        29 |
LOC:          |      77 |     * |      WARNING |        77 |
Clone analysis:
          File :grass/branches/develbranch_6/vector/v.to.db/query.c
          Function
query(Begins at: 9, Ends at:192)
Complexity:   |      29 |   *** |      MONSTER |        29 |
CalledNBR:    |      64 |   *** |      MONSTER |        64 |
LOC:          |     184 |   *** |      MONSTER |       184 |
Clone analysis:
          File :grass/branches/develbranch_6/vector/v.to.db/report.c
          Function
print_stat(Begins at: 172, Ends at:189)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |      14 |     * |      WARNING |        14 |
LOC:          |      18 |       |           OK |        18 |
 at least 1 values are close to an outlier please consider revising code!
report(Begins at: 5, Ends at:170)
Complexity:   |      55 |   *** |      MONSTER |        55 |
CalledNBR:    |      58 |   *** |      MONSTER |        58 |
LOC:          |     166 |   *** |      MONSTER |       166 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Thu Dec 11 11:35:38 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
