[GRASS-QA] GRASS QA: hamish |null_val.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Wed Dec 17 12:02:00 EST 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/gis/null_val.c
Function
EmbedGivenNulls(Begins at: 63, Ends at:97)
| New Metrics |Old Metrics|
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 35 | | OK | 35 |
Conclusion: | this function is a WARNING |
at least 2 values are close to an outlier please consider revising code!
G_insert_c_null_values(Begins at: 547, Ends at:550)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
at least 1 values are close to an outlier please consider revising code!
G_insert_d_null_values(Begins at: 603, Ends at:606)
G_insert_f_null_values(Begins at: 575, Ends at:578)
G_insert_null_values(Begins at: 518, Ends at:522)
LOC: | 5 | | OK | 5 |
G_is_c_null_value(Begins at: 377, Ends at:395)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 19 | | OK | 19 |
Conclusion: | this function is a OK |
metrics are OK
G_is_d_null_value(Begins at: 468, Ends at:486)
metrics are OK
G_is_f_null_value(Begins at: 428, Ends at:446)
metrics are OK
G_is_null_value(Begins at: 340, Ends at:356)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 17 | | OK | 17 |
G_set_c_null_value(Begins at: 237, Ends at:256)
Complexity: | 3 | | OK | 3 |
LOC: | 20 | | OK | 20 |
metrics are OK
G_set_d_null_value(Begins at: 295, Ends at:314)
metrics are OK
G_set_f_null_value(Begins at: 266, Ends at:285)
metrics are OK
G_set_null_value(Begins at: 207, Ends at:227)
LOC: | 21 | | OK | 21 |
G__check_null_bit(Begins at: 617, Ends at:637)
Complexity: | 2 | | OK | 2 |
G__convert_01_flags(Begins at: 702, Ends at:730)
LOC: | 29 | | OK | 29 |
G__convert_flags_01(Begins at: 741, Ends at:766)
LOC: | 26 | | OK | 26 |
G__init_null_bits(Begins at: 776, Ends at:798)
LOC: | 23 | | OK | 23 |
metrics are OK
G__init_null_patterns(Begins at: 131, Ends at:171)
CalledNBR: | 3 | | OK | 3 |
LOC: | 41 | | OK | 41 |
metrics are OK
G__set_flags_from_01_random(Begins at: 653, Ends at:691)
ParamNBR: | 5 | * | WARNING | 5 |
LOC: | 39 | | OK | 39 |
G__set_null_value(Begins at: 185, Ends at:196)
LOC: | 12 | | OK | 12 |
InitError(Begins at: 108, Ends at:118)
CalledNBR: | 7 | | OK | 7 |
LOC: | 11 | | OK | 11 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Dec 17 12:16:59 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
