[GRASS-QA] GRASS QA: martinl |export_band.c main.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Wed Dec 17 12:37:29 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/raster/r.out.gdal/export_band.c
The system don't find class, method and function
in this file during analysis!
File :grass/branches/develbranch_6/raster/r.out.gdal/main.c
Function
AttachMetadata(Begins at: 355, Ends at:371)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 17 | | OK | 17 |
Conclusion: | this function is a OK |
metrics are OK
import_band(Begins at: 84, Ends at:353)
Complexity: | 37 | *** | MONSTER | 37 |
ParamNBR: | 8 | ** | BABY-MONSTER | 8 |
CalledNBR: | 71 | *** | MONSTER | 71 |
LOC: | 270 | *** | MONSTER | 270 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
main(Begins at: 374, Ends at:755)
Complexity: | 50 | *** | MONSTER | 50 |
CalledNBR: | 105 | *** | MONSTER | 105 |
LOC: | 382 | *** | MONSTER | 382 |
supported_formats(Begins at: 37, Ends at:82)
Complexity: | 9 | * | WARNING | 9 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 46 | * | WARNING | 46 |
Conclusion: | this function is a WARNING |
at least 3 values are close to an outlier please consider revising code!
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Dec 17 12:52:28 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
