[GRASS-QA] GRASS QA: neteler |main.c r3.info.main.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Wed Nov 12 01:18:43 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/raster/r.info/main.c
Function
compose_line(Begins at: 417, Ends at:431)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
format_double(Begins at: 410, Ends at:414)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 5 | | OK | 5 |
Conclusion: | this function is a OK |
metrics are OK
main(Begins at: 39, Ends at:407)
Complexity: | 45 | *** | MONSTER | 45 |
CalledNBR: | 128 | *** | MONSTER | 128 |
LOC: | 369 | *** | MONSTER | 369 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/raster3d/base/r3.info.main.c
Function
format_double(Begins at: 430, Ends at:436)
LOC: | 7 | | OK | 7 |
metrics are OK
main(Begins at: 46, Ends at:427)
Complexity: | 49 | *** | MONSTER | 49 |
CalledNBR: | 183 | *** | MONSTER | 183 |
LOC: | 382 | *** | MONSTER | 382 |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Nov 12 01:38:33 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
