[GRASS-QA] GRASS QA: marisn |array.c | no clones | 0 monsters |0
	warnings
    soccerlab.info at gmail.com
    Wed Nov 12 01:23:54 EST 2008
Hello marisn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/vector/Vlib/array.c
          Function
cmp(Begins at: 203, Ends at:213)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
in_array(Begins at: 216, Ends at:226)
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
Vect_new_varray(Begins at: 44, Ends at:62)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      19 |       |           OK |        19 |
metrics are OK
Vect_set_varray_from_cat_list(Begins at: 129, Ends at:200)
Complexity:   |      13 |    ** | BABY-MONSTER |        13 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      72 |     * |      WARNING |        72 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Vect_set_varray_from_cat_string(Begins at: 83, Ends at:108)
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      26 |       |           OK |        26 |
Vect_set_varray_from_db(Begins at: 248, Ends at:369)
Complexity:   |      16 |    ** | BABY-MONSTER |        16 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |     122 |    ** | BABY-MONSTER |       122 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Wed Nov 12 01:43:45 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
