[GRASS-QA] GRASS QA: glynn |global.h main.c read_list.c do_remove.c ...| 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Nov 12 02:36:39 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/general/g.mlist/global.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/general/g.mlist/main.c
          File :grass/trunk/general/g.mlist/read_list.c
          File :grass/trunk/general/g.mremove/do_remove.c
          File :grass/trunk/general/g.mremove/global.h
          File :grass/trunk/general/g.mremove/main.c
          File :grass/trunk/general/g.mremove/read_list.c
          File :grass/trunk/general/manage/list.h
          Class
list(Begins at: 4, Ends at:14)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/general/manage/cmd/copy.c
          Function
main(Begins at: 27, Ends at:99)
              |          New Metrics           |Old Metrics|
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      30 |    ** | BABY-MONSTER |        30 |
LOC:          |      73 |     * |      WARNING |        73 |
Conclusion:   | this function is a  BABY-MONSTER           |
 metric are OUT OF RANGE!
Clone analysis:
          File :grass/trunk/general/manage/cmd/init.c
          Function
init(Begins at: 4, Ends at:11)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :grass/trunk/general/manage/cmd/list.c
          Function
main(Begins at: 29, Ends at:109)
Complexity:   |      10 |     * |      WARNING |        10 |
CalledNBR:    |      27 |    ** | BABY-MONSTER |        27 |
LOC:          |      81 |     * |      WARNING |        81 |
parse(Begins at: 111, Ends at:121)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      11 |       |           OK |        11 |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/general/manage/cmd/list.c clones of parse are:
          /var/project-manager/grass/grassSVN/grass-addons/general/g.xlist/main.c  parse
          File :grass/trunk/general/manage/cmd/remove.c
          Function
check_reclass(Begins at: 28, Ends at:83)
Complexity:   |      12 |     * |      WARNING |        12 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      56 |     * |      WARNING |        56 |
Conclusion:   | this function is a       WARNING           |
 at least 4 values are close to an outlier please consider revising code!
main(Begins at: 85, Ends at:146)
Complexity:   |       9 |     * |      WARNING |         9 |
LOC:          |      62 |     * |      WARNING |        62 |
 at least 3 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/general/manage/cmd/rename.c
          Function
main(Begins at: 27, Ends at:145)
Complexity:   |      15 |    ** | BABY-MONSTER |        15 |
CalledNBR:    |      56 |   *** |      MONSTER |        56 |
LOC:          |     119 |    ** | BABY-MONSTER |       119 |
Conclusion:   | this function is a       MONSTER           |
Clone analysis:
          File :grass/trunk/general/manage/lib/add_elem.c
          Function
add_element(Begins at: 2, Ends at:20)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      19 |       |           OK |        19 |
metrics are OK
Clone analysis:
          File :grass/trunk/general/manage/lib/do_copy.c
          Function
do_copy(Begins at: 12, Ends at:66)
ParamNBR:     |       4 |     * |      WARNING |         4 |
LOC:          |      55 |     * |      WARNING |        55 |
Clone analysis:
          File :grass/trunk/general/manage/lib/do_list.c
          Function
do_list(Begins at: 2, Ends at:7)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
Clone analysis:
          File :grass/trunk/general/manage/lib/do_remove.c
          Function
do_remove(Begins at: 12, Ends at:108)
Complexity:   |      25 |   *** |      MONSTER |        25 |
CalledNBR:    |      51 |   *** |      MONSTER |        51 |
LOC:          |      97 |    ** | BABY-MONSTER |        97 |
Clone analysis:
          File :grass/trunk/general/manage/lib/do_rename.c
          Function
do_rename(Begins at: 12, Ends at:108)
CalledNBR:    |      52 |   *** |      MONSTER |        52 |
Clone analysis:
          File :grass/trunk/general/manage/lib/empty.c
          Function
empty(Begins at: 6, Ends at:25)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      20 |       |           OK |        20 |
metrics are OK
Clone analysis:
          File :grass/trunk/general/manage/lib/find.c
          Function
find(Begins at: 4, Ends at:16)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      13 |       |           OK |        13 |
 at least 1 values are close to an outlier please consider revising code!
Clone analysis:
          File :grass/trunk/general/manage/lib/get_len.c
          Function
get_description_len(Begins at: 4, Ends at:17)
LOC:          |      14 |       |           OK |        14 |
metrics are OK
Clone analysis:
          File :grass/trunk/general/manage/lib/read_list.c
          Function
format_error(Begins at: 105, Ends at:111)
LOC:          |       7 |       |           OK |         7 |
read_list(Begins at: 25, Ends at:103)
CalledNBR:    |      28 |    ** | BABY-MONSTER |        28 |
LOC:          |      79 |     * |      WARNING |        79 |
Clone analysis:
          File :grass/trunk/general/manage/lib/show_elem.c
          Function
show_elements(Begins at: 4, Ends at:17)
metrics are OK
Clone analysis:
          File :grass/trunk/general/manage/lib/sighold.c
          Function
hold_signals(Begins at: 5, Ends at:21)
LOC:          |      17 |       |           OK |        17 |
metrics are OK
Clone analysis:
          File :grass/trunk/lib/manage/add_elem.c
          File :grass/trunk/lib/manage/do_copy.c
          File :grass/trunk/lib/manage/do_list.c
          File :grass/trunk/lib/manage/do_remove.c
          File :grass/trunk/lib/manage/do_rename.c
          File :grass/trunk/lib/manage/empty.c
          File :grass/trunk/lib/manage/find.c
          File :grass/trunk/lib/manage/get_len.c
          File :grass/trunk/lib/manage/list.h
          File :grass/trunk/lib/manage/read_list.c
          File :grass/trunk/lib/manage/show_elem.c
          File :grass/trunk/lib/manage/sighold.c
____________________________________________
Threshold grass key metrics values at Wed Nov 12 02:56:31 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
