[GRASS-QA] GRASS QA: martinl |main.c stats.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Nov 12 02:49:59 EST 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.colors/main.c
          Function
find_rule(Begins at: 124, Ends at:133)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      10 |       |           OK |        10 |
Conclusion:   | this function is a            OK           |
metrics are OK
list_rules(Begins at: 116, Ends at:122)
Complexity:   |       2 |       |           OK |         2 |
LOC:          |       7 |       |           OK |         7 |
metrics are OK
main(Begins at: 135, Ends at:372)
Complexity:   |      37 |   *** |      MONSTER |        37 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      99 |   *** |      MONSTER |        99 |
LOC:          |     238 |   *** |      MONSTER |       238 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
rules_descriptions(Begins at: 76, Ends at:114)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      11 |       |           OK |        11 |
LOC:          |      39 |       |           OK |        39 |
metrics are OK
rules_list(Begins at: 50, Ends at:74)
Complexity:   |       4 |       |           OK |         4 |
CalledNBR:    |       3 |     * |      WARNING |         3 |
LOC:          |      25 |       |           OK |        25 |
Conclusion:   | this function is a       WARNING           |
 at least 1 values are close to an outlier please consider revising code!
scan_rules(Begins at: 35, Ends at:48)
Complexity:   |       1 |       |           OK |         1 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.colors/stats.c
          Function
get_fp_stats(Begins at: 57, Ends at:127)
Complexity:   |      11 |       |           OK |        11 |
ParamNBR:     |       6 |     * |      WARNING |         6 |
CalledNBR:    |      26 |     * |      WARNING |        22 |
LOC:          |      71 |       |           OK |        68 |
 at least 2 values are close to an outlier please consider revising code!
get_stats(Begins at: 26, Ends at:55)
Complexity:   |       4 |     * |      WARNING |         4 |
ParamNBR:     |       3 |    ** | BABY-MONSTER |         3 |
CalledNBR:    |      20 |    ** | BABY-MONSTER |        15 |
LOC:          |      30 |     * |      WARNING |        27 |
Conclusion:   | this function is a  BABY-MONSTER           |
Clone analysis:
____________________________________________
Threshold grass key metrics values at Wed Nov 12 03:09:50 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
