[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Mon Nov 17 22:24:48 EST 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.quantile/main.c
Class
bin(Begins at: 19, Ends at:24)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
compare_dcell(Begins at: 162, Ends at:172)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a OK |
metrics are OK
compute_quantiles(Begins at: 191, Ends at:215)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 25 | | OK | 25 |
metrics are OK
fill_bins(Begins at: 128, Ends at:160)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 33 | | OK | 33 |
metrics are OK
get_quantile(Begins at: 52, Ends at:55)
Complexity: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
metrics are OK
get_slot(Begins at: 41, Ends at:50)
CalledNBR: | 1 | | OK | 1 |
LOC: | 10 | | OK | 10 |
metrics are OK
get_slot_counts(Begins at: 57, Ends at:86)
Complexity: | 4 | | OK | 4 |
LOC: | 30 | | OK | 30 |
metrics are OK
initialize_bins(Begins at: 88, Ends at:126)
LOC: | 39 | | OK | 39 |
metrics are OK
main(Begins at: 226, Ends at:329)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 47 | *** | MONSTER | 45 |
LOC: | 104 | ** | BABY-MONSTER | 95 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
sort_bins(Begins at: 174, Ends at:189)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 16 | | OK | 16 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon Nov 17 22:45:55 EST 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
