[GRASS-QA] GRASS QA: neteler |main.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Mon Nov 17 22:31:53 EST 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/raster/r.quantile/main.c
          Class
bin(Begins at: 19, Ends at:24)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Function
compare_dcell(Begins at: 162, Ends at:172)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |       |           OK |         3 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
compute_quantiles(Begins at: 191, Ends at:215)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
fill_bins(Begins at: 128, Ends at:160)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      33 |       |           OK |        33 |
metrics are OK
get_quantile(Begins at: 52, Ends at:55)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
get_slot(Begins at: 41, Ends at:50)
CalledNBR:    |       1 |       |           OK |         1 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
get_slot_counts(Begins at: 57, Ends at:86)
Complexity:   |       4 |       |           OK |         4 |
LOC:          |      30 |       |           OK |        30 |
metrics are OK
initialize_bins(Begins at: 88, Ends at:126)
LOC:          |      39 |       |           OK |        39 |
metrics are OK
main(Begins at: 217, Ends at:311)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      45 |   *** |      MONSTER |        45 |
LOC:          |      95 |    ** | BABY-MONSTER |        95 |
Conclusion:   | this function is a       MONSTER           |
 metric are OUT OF RANGE!
sort_bins(Begins at: 174, Ends at:189)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      16 |       |           OK |        16 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Mon Nov 17 22:53:00 EST 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
    http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
