[GRASS-QA] GRASS QA: neteler |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Oct 2 12:34:02 EDT 2008
Hello neteler,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass-addons/raster/r.sun_horizon/r.horizon/main.c
Function
amax1(Begins at: 659, Ends at:672)
| New Metrics |Old Metrics|
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 14 | | OK | 14 |
Conclusion: | this function is a OK |
metrics are OK
amin1(Begins at: 674, Ends at:687)
metrics are OK
calculate(Begins at: 1037, Ends at:1273)
Complexity: | 28 | *** | MONSTER | 28 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 34 | ** | BABY-MONSTER | 34 |
LOC: | 237 | *** | MONSTER | 237 |
Conclusion: | this function is a MONSTER |
metrics are OK
calculate_shadow(Begins at: 774, Ends at:876)
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 103 | ** | BABY-MONSTER | 103 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
calculate_shadow_onedirection(Begins at: 764, Ends at:770)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 7 | | OK | 7 |
metrics are OK
com_par(Begins at: 724, Ends at:746)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 23 | | OK | 23 |
metrics are OK
distance(Begins at: 146, Ends at:155)
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a WARNING |
metrics are OK
horizon_height(Begins at: 748, Ends at:761)
metrics are OK
INPUT(Begins at: 534, Ends at:605)
Complexity: | 15 | ** | BABY-MONSTER | 15 |
CalledNBR: | 18 | * | WARNING | 18 |
LOC: | 72 | * | WARNING | 72 |
metrics are OK
isMode(Begins at: 134, Ends at:137)
LOC: | 4 | | OK | 4 |
metrics are OK
main(Begins at: 159, Ends at:530)
Complexity: | 37 | *** | MONSTER | 37 |
CalledNBR: | 112 | *** | MONSTER | 112 |
LOC: | 372 | *** | MONSTER | 372 |
metrics are OK
max(Begins at: 705, Ends at:718)
metrics are OK
min(Begins at: 690, Ends at:703)
metrics are OK
new_point(Begins at: 881, Ends at:919)
LOC: | 39 | | OK | 39 |
metrics are OK
OUTGR(Begins at: 610, Ends at:656)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 47 | * | WARNING | 47 |
metrics are OK
searching(Begins at: 993, Ends at:1031)
Complexity: | 7 | * | WARNING | 7 |
metrics are OK
setMode(Begins at: 138, Ends at:141)
metrics are OK
test_low_res(Begins at: 922, Ends at:990)
CalledNBR: | 15 | * | WARNING | 15 |
LOC: | 69 | * | WARNING | 69 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 02 12:45:15 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
