[GRASS-QA] GRASS QA: glynn |open.c | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Oct 2 13:11:36 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/gis/open.c
          Function
G_fopen_append(Begins at: 252, Ends at:262)
              |          New Metrics           |Old Metrics|
Complexity:   |       2 |       |           OK |         2 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      11 |       |           OK |        11 |
Conclusion:   | this function is a            OK           |
metrics are OK
G_fopen_modify(Begins at: 279, Ends at:289)
metrics are OK
G_fopen_new(Begins at: 197, Ends at:206)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
G_fopen_old(Begins at: 226, Ends at:235)
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |       2 |       |           OK |         2 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
G_open_new(Begins at: 125, Ends at:128)
Complexity:   |       1 |       |           OK |         1 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
G_open_old(Begins at: 147, Ends at:150)
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
G_open_update(Begins at: 168, Ends at:177)
metrics are OK
G__open(Begins at: 49, Ends at:104)
Complexity:   |      11 |     * |      WARNING |        11 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      20 |     * |      WARNING |        20 |
LOC:          |      56 |     * |      WARNING |        56 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 02 13:22:49 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
