[GRASS-QA] GRASS QA: marisn |build.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Thu Oct 2 13:36:09 EDT 2008
Hello marisn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/vector/Vlib/build.c
Function
format(Begins at: 29, Ends at:33)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 0 | | OK | 0 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 5 | | OK | 5 |
Conclusion: | this function is a OK |
metrics are OK
prnmsg(Begins at: 48, Ends at:62)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 15 | | OK | 15 |
metrics are OK
Vect_build(Begins at: 73, Ends at:76)
CalledNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
metrics are OK
Vect_build_partial(Begins at: 128, Ends at:248)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 46 | *** | MONSTER | 46 |
LOC: | 121 | ** | BABY-MONSTER | 121 |
Conclusion: | this function is a MONSTER |
metrics are OK
Vect_get_built(Begins at: 86, Ends at:89)
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
metrics are OK
Vect_save_spatial_index(Begins at: 408, Ends at:440)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 33 | | OK | 33 |
Conclusion: | this function is a WARNING |
metrics are OK
Vect_save_topo(Begins at: 257, Ends at:289)
metrics are OK
Vect_spatial_index_dump(Begins at: 451, Ends at:462)
CalledNBR: | 3 | | OK | 3 |
LOC: | 12 | | OK | 12 |
metrics are OK
Vect_topo_dump(Begins at: 300, Ends at:398)
Complexity: | 13 | ** | BABY-MONSTER | 13 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 99 | ** | BABY-MONSTER | 99 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 02 13:47:22 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
