[GRASS-QA] GRASS QA: glynn |main.c do_graph.c local_proto.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Thu Oct 2 13:42:06 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/display/d.erase/main.c
          Function
main(Begins at: 21, Ends at:62)
              |          New Metrics           |Old Metrics|
Complexity:   |       4 |       |           OK |         4 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      17 |     * |      WARNING |        17 |
LOC:          |      42 |     * |      WARNING |        42 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/display/d.graph/do_graph.c
          Function
check_alloc(Begins at: 254, Ends at:277)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      24 |       |           OK |        24 |
Conclusion:   | this function is a            OK           |
metrics are OK
do_color(Begins at: 97, Ends at:127)
Complexity:   |       5 |       |           OK |         5 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      31 |       |           OK |        31 |
metrics are OK
do_draw(Begins at: 49, Ends at:75)
CalledNBR:    |       6 |       |           OK |         6 |
LOC:          |      27 |       |           OK |        27 |
metrics are OK
do_icon(Begins at: 279, Ends at:328)
Complexity:   |       9 |     * |      WARNING |         9 |
CalledNBR:    |      18 |     * |      WARNING |        18 |
LOC:          |      50 |     * |      WARNING |        50 |
metrics are OK
do_linewidth(Begins at: 129, Ends at:142)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       5 |       |           OK |         5 |
LOC:          |      14 |       |           OK |        14 |
metrics are OK
do_move(Begins at: 77, Ends at:95)
LOC:          |      19 |       |           OK |        19 |
metrics are OK
do_poly(Begins at: 145, Ends at:200)
Complexity:   |      10 |     * |      WARNING |        10 |
LOC:          |      56 |     * |      WARNING |        56 |
metrics are OK
do_rotate(Begins at: 228, Ends at:239)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
do_size(Begins at: 202, Ends at:226)
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      25 |       |           OK |        25 |
metrics are OK
do_symbol(Begins at: 330, Ends at:433)
Complexity:   |      11 |     * |      WARNING |        11 |
CalledNBR:    |      41 |   *** |      MONSTER |        41 |
LOC:          |     104 |    ** | BABY-MONSTER |       104 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
do_text(Begins at: 241, Ends at:252)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
set_graph_stuff(Begins at: 25, Ends at:37)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      13 |       |           OK |        13 |
metrics are OK
set_last_color(Begins at: 436, Ends at:449)
ParamNBR:     |       4 |     * |      WARNING |         4 |
metrics are OK
set_text_size(Begins at: 39, Ends at:47)
LOC:          |       9 |       |           OK |         9 |
metrics are OK
Clone analysis:
          File :grass/trunk/display/d.graph/local_proto.h
The system don't find class, method and function
 in this file during analysis!
____________________________________________
Threshold GRASS6 key metrics values at Thu Oct 02 13:53:20 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
