[GRASS-QA] GRASS QA: martinl |main.c parser.c | no clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Tue Oct 14 18:40:40 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/display/d.vect/main.c
Function
icon_files(Begins at: 32, Ends at:76)
| New Metrics |Old Metrics|
Complexity: | 8 | * | WARNING | 8 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 14 | * | WARNING | 14 |
LOC: | 45 | * | WARNING | 45 |
Conclusion: | this function is a WARNING |
at least 4 values are close to an outlier please consider revising code!
main(Begins at: 78, Ends at:749)
Complexity: | 83 | *** | MONSTER | 83 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 216 | *** | MONSTER | 216 |
LOC: | 672 | *** | MONSTER | 672 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
File :grass/branches/develbranch_6/lib/gis/parser.c
Class
Item(Begins at: 108, Ends at:113)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
check_an_opt(Begins at: 2206, Ends at:2248)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 43 | * | WARNING | 43 |
at least 5 values are close to an outlier please consider revising code!
check_double(Begins at: 2314, Ends at:2350)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 6 | | OK | 6 |
LOC: | 37 | | OK | 37 |
Conclusion: | this function is a BABY-MONSTER |
check_int(Begins at: 2250, Ends at:2286)
check_multiple_opts(Begins at: 2463, Ends at:2499)
CalledNBR: | 5 | | OK | 5 |
at least 2 values are close to an outlier please consider revising code!
check_opts(Begins at: 2170, Ends at:2204)
Complexity: | 7 | * | WARNING | 7 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 35 | | OK | 35 |
check_overwrite(Begins at: 2502, Ends at:2565)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 64 | * | WARNING | 64 |
check_required(Begins at: 2378, Ends at:2401)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 24 | | OK | 24 |
Conclusion: | this function is a OK |
metrics are OK
check_string(Begins at: 2352, Ends at:2376)
Complexity: | 9 | * | WARNING | 9 |
LOC: | 25 | | OK | 25 |
contains(Begins at: 2088, Ends at:2096)
Complexity: | 3 | | OK | 3 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 9 | | OK | 9 |
metrics are OK
generate_tcl(Begins at: 1820, Ends at:1918)
CalledNBR: | 34 | ** | BABY-MONSTER | 34 |
LOC: | 99 | ** | BABY-MONSTER | 99 |
gis_prompt(Begins at: 2725, Ends at:2769)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 20 | * | WARNING | 20 |
G_define_flag(Begins at: 179, Ends at:216)
CalledNBR: | 4 | | OK | 4 |
LOC: | 38 | | OK | 38 |
metrics are OK
G_define_module(Begins at: 650, Ends at:663)
Complexity: | 1 | | OK | 1 |
LOC: | 14 | | OK | 14 |
metrics are OK
G_define_option(Begins at: 235, Ends at:286)
LOC: | 52 | * | WARNING | 52 |
G_define_standard_option(Begins at: 315, Ends at:641)
Complexity: | 38 | *** | MONSTER | 38 |
CalledNBR: | 43 | *** | MONSTER | 43 |
LOC: | 327 | *** | MONSTER | 327 |
G_disable_interactive(Begins at: 158, Ends at:163)
LOC: | 6 | | OK | 6 |
metrics are OK
G_gui(Begins at: 1978, Ends at:1993)
LOC: | 16 | | OK | 16 |
metrics are OK
G_gui_tcltk(Begins at: 1923, Ends at:1952)
Complexity: | 6 | * | WARNING | 6 |
CalledNBR: | 12 | * | WARNING | 12 |
LOC: | 30 | | OK | 30 |
at least 3 values are close to an outlier please consider revising code!
G_gui_wx(Begins at: 1957, Ends at:1969)
LOC: | 13 | | OK | 13 |
metrics are OK
G_parser(Begins at: 702, Ends at:963)
Complexity: | 41 | *** | MONSTER | 41 |
CalledNBR: | 85 | *** | MONSTER | 85 |
LOC: | 262 | *** | MONSTER | 262 |
G_recreate_command(Begins at: 2779, Ends at:2878)
CalledNBR: | 26 | ** | BABY-MONSTER | 26 |
LOC: | 100 | ** | BABY-MONSTER | 100 |
G_script(Begins at: 1701, Ends at:1813)
Complexity: | 24 | *** | MONSTER | 24 |
CalledNBR: | 46 | *** | MONSTER | 46 |
LOC: | 113 | ** | BABY-MONSTER | 113 |
G_tcltk(Begins at: 1998, Ends at:2006)
metrics are OK
G_usage(Begins at: 1013, Ends at:1184)
Complexity: | 34 | *** | MONSTER | 34 |
CalledNBR: | 53 | *** | MONSTER | 53 |
LOC: | 172 | *** | MONSTER | 172 |
G_usage_html(Begins at: 1477, Ends at:1696)
Complexity: | 42 | *** | MONSTER | 42 |
LOC: | 220 | *** | MONSTER | 220 |
G_usage_xml(Begins at: 1239, Ends at:1472)
Complexity: | 31 | *** | MONSTER | 31 |
CalledNBR: | 87 | *** | MONSTER | 87 |
LOC: | 234 | *** | MONSTER | 234 |
interactive(Begins at: 2567, Ends at:2593)
LOC: | 27 | | OK | 27 |
interactive_flag(Begins at: 2595, Ends at:2604)
LOC: | 10 | | OK | 10 |
metrics are OK
interactive_option(Begins at: 2606, Ends at:2693)
CalledNBR: | 37 | *** | MONSTER | 37 |
LOC: | 88 | * | WARNING | 88 |
is_option(Begins at: 2098, Ends at:2111)
metrics are OK
print_escaped_for_html(Begins at: 1218, Ends at:1232)
LOC: | 15 | | OK | 15 |
metrics are OK
print_escaped_for_xml(Begins at: 1194, Ends at:1211)
LOC: | 18 | | OK | 18 |
set_flag(Begins at: 2059, Ends at:2083)
metrics are OK
set_option(Begins at: 2113, Ends at:2168)
LOC: | 56 | * | WARNING | 56 |
show(Begins at: 2045, Ends at:2057)
metrics are OK
show_options(Begins at: 2015, Ends at:2043)
CalledNBR: | 11 | * | WARNING | 11 |
LOC: | 29 | | OK | 29 |
split_gisprompt(Begins at: 2695, Ends at:2723)
split_opts(Begins at: 2403, Ends at:2461)
LOC: | 59 | * | WARNING | 59 |
uses_new_gisprompt(Begins at: 966, Ends at:988)
Complexity: | 5 | | OK | 5 |
LOC: | 23 | | OK | 23 |
metrics are OK
Clone analysis:
____________________________________________
Threshold grass key metrics values at Tue Oct 14 18:54:22 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/index.html
