[GRASS-QA] GRASS QA: hamish |local_proto.h main.c printwindow.c | 1
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Sat Oct 25 00:20:54 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/general/g.region/local_proto.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/general/g.region/main.c
Function
die(Begins at: 826, Ends at:832)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 2 | | OK | 2 |
LOC: | 7 | | OK | 7 |
Conclusion: | this function is a OK |
metrics are OK
llinfo(Begins at: 845, Ends at:854)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 10 | | OK | 10 |
Conclusion: | this function is a WARNING |
at least 1 values are close to an outlier please consider revising code!
main(Begins at: 29, Ends at:824)
Complexity: | 120 | *** | MONSTER | 120 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 259 | *** | MONSTER | 259 |
LOC: | 796 | *** | MONSTER | 796 |
Conclusion: | this function is a MONSTER |
metric are OUT OF RANGE!
nsew(Begins at: 834, Ends at:843)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 6 | | OK | 6 |
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/general/g.region/main.c clones of llinfo are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/gis/open_misc.c G_fopen_new_misc
File :grass/trunk/general/g.region/printwindow.c
Function
print_window(Begins at: 8, Ends at:653)
Complexity: | 71 | *** | MONSTER | 71 |
CalledNBR: | 232 | *** | MONSTER | 232 |
LOC: | 646 | *** | MONSTER | 646 |
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold grass key metrics values at Sat Oct 25 00:36:49 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
Please visite our web site on your project at :
http://web.soccerlab.polymtl.ca/project-manager/grass-website/index.html
