[GRASS-QA] GRASS QA: martinl |break.c | 3 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Fri Sep 5 11:05:09 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/lib/vector/vedit/break.c
Function
connect_lines(Begins at: 197, Ends at:327)
| New Metrics |Old Metrics|
Complexity: | 13 | ** | BABY-MONSTER | 13 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 34 | ** | BABY-MONSTER | 34 |
LOC: | 131 | ** | BABY-MONSTER | 131 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
Vedit_connect_lines(Begins at: 152, Ends at:195)
Complexity: | 7 | * | WARNING | 7 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 44 | * | WARNING | 44 |
Conclusion: | this function is a WARNING |
metrics are OK
Vedit_split_lines(Begins at: 34, Ends at:133)
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 23 | ** | BABY-MONSTER | 23 |
LOC: | 100 | ** | BABY-MONSTER | 100 |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
Vedit_connect_lines Vedit_split_lines
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/vedit/break.c clones of connect_lines are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/vedit/break.c connect_lines
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/vedit/break.c clones of Vedit_connect_lines are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/vedit/break.c Vedit_connect_lines
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/vedit/break.c clones of Vedit_split_lines are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/vedit/break.c Vedit_split_lines
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 11:10:31 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
