[GRASS-QA] GRASS QA: glynn |main.c main.c display.c main.c ...| 7
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Sep 5 11:20:45 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/display/d.his/main.c
Function
main(Begins at: 31, Ends at:271)
| New Metrics |Old Metrics|
Complexity: | 27 | *** | MONSTER | 27 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 84 | *** | MONSTER | 84 |
LOC: | 241 | *** | MONSTER | 241 |
Conclusion: | this function is a MONSTER |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/display/d.profile/main.c
Function
main(Begins at: 51, Ends at:425)
Complexity: | 36 | *** | MONSTER | 36 |
CalledNBR: | 176 | *** | MONSTER | 176 |
LOC: | 375 | *** | MONSTER | 375 |
metrics are OK
myDcell(Begins at: 427, Ends at:467)
Complexity: | 6 | * | WARNING | 6 |
ParamNBR: | 3 | * | WARNING | 3 |
CalledNBR: | 20 | * | WARNING | 20 |
LOC: | 41 | | OK | 41 |
Conclusion: | this function is a WARNING |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
myDcell
In /var/project-manager/grass/grassSVN/grass/trunk/display/d.profile/main.c clones of main are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/display/d.profile/main.c main
In /var/project-manager/grass/grassSVN/grass/trunk/display/d.profile/main.c clones of myDcell are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/display/d.profile/main.c myDcell
File :grass/trunk/display/d.rast/display.c
Function
cell_draw(Begins at: 46, Ends at:92)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 20 | | OK | 20 |
LOC: | 47 | | OK | 47 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
display(Begins at: 12, Ends at:44)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 6 | * | WARNING | 6 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 33 | | OK | 33 |
metrics are OK
mask_raster_array(Begins at: 94, Ends at:103)
ParamNBR: | 4 | ** | BABY-MONSTER | 4 |
CalledNBR: | 2 | * | WARNING | 2 |
LOC: | 10 | * | WARNING | 10 |
metrics are OK
Clone analysis:
mask_raster_array
In /var/project-manager/grass/grassSVN/grass/trunk/display/d.rast/display.c clones of cell_draw are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/display/d.rast/display.c cell_draw
In /var/project-manager/grass/grassSVN/grass/trunk/display/d.rast/display.c clones of mask_raster_array are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/display/d.rast/display.c mask_raster_array
File :grass/trunk/display/d.rgb/main.c
Class
band(Begins at: 28, Ends at:35)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
main(Begins at: 39, Ends at:143)
Complexity: | 14 | ** | BABY-MONSTER | 14 |
CalledNBR: | 41 | *** | MONSTER | 41 |
LOC: | 105 | ** | BABY-MONSTER | 105 |
metrics are OK
Clone analysis:
File :grass/trunk/include/display.h
The system don't find class, method and function
in this file during analysis!
File :grass/trunk/lib/display/raster.c
Function
draw_cell(Begins at: 83, Ends at:116)
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 34 | | OK | 34 |
metrics are OK
D_cell_draw_end(Begins at: 203, Ends at:206)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
Conclusion: | this function is a OK |
metrics are OK
D_cell_draw_setup(Begins at: 133, Ends at:149)
CalledNBR: | 7 | | OK | 7 |
LOC: | 17 | | OK | 17 |
metrics are OK
D_draw_cell(Begins at: 78, Ends at:81)
metrics are OK
D_draw_c_raster(Begins at: 56, Ends at:59)
metrics are OK
D_draw_d_raster(Begins at: 46, Ends at:49)
metrics are OK
D_draw_f_raster(Begins at: 51, Ends at:54)
metrics are OK
D_draw_raster(Begins at: 39, Ends at:44)
LOC: | 6 | | OK | 6 |
metrics are OK
D_draw_raster_RGB(Begins at: 151, Ends at:201)
ParamNBR: | 10 | *** | MONSTER | 10 |
CalledNBR: | 17 | * | WARNING | 17 |
LOC: | 51 | * | WARNING | 51 |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
D_cell_draw_setup D_draw_raster_RGB
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/raster.c clones of draw_cell are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/raster.c draw_cell
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/raster.c clones of D_cell_draw_setup are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/raster.c D_cell_draw_setup
In /var/project-manager/grass/grassSVN/grass/trunk/lib/display/raster.c clones of D_draw_raster_RGB are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/display/raster.c D_draw_raster_RGB
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 11:26:07 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
