[GRASS-QA] GRASS QA: glynn |main.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Fri Sep 5 12:00:35 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/raster/r.external/main.c
Class
band_info(Begins at: 35, Ends at:43)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
check_projection(Begins at: 72, Ends at:184)
| New Metrics |Old Metrics|
Complexity: | 19 | | OK | 19 |
ParamNBR: | 3 | ** | BABY-MONSTER | 3 |
CalledNBR: | 46 | * | WARNING | 46 |
LOC: | 113 | | OK | 113 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
create_map(Begins at: 402, Ends at:440)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 6 | | OK | 6 |
CalledNBR: | 15 | | OK | 15 |
LOC: | 39 | | OK | 39 |
Conclusion: | this function is a OK |
metrics are OK
list_formats(Begins at: 45, Ends at:70)
Complexity: | 4 | * | WARNING | 4 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 9 | *** | MONSTER | 9 |
LOC: | 26 | ** | BABY-MONSTER | 26 |
Conclusion: | this function is a MONSTER |
metrics are OK
main(Begins at: 442, Ends at:565)
Complexity: | 11 | | OK | 11 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 51 | | OK | 51 |
LOC: | 124 | | OK | 124 |
metrics are OK
make_cell(Begins at: 347, Ends at:365)
Complexity: | 4 | | OK | 4 |
ParamNBR: | 2 | * | WARNING | 2 |
CalledNBR: | 8 | * | WARNING | 8 |
LOC: | 19 | | OK | 19 |
Conclusion: | this function is a WARNING |
metrics are OK
make_link(Begins at: 367, Ends at:400)
Complexity: | 5 | | OK | 5 |
ParamNBR: | 4 | | OK | 4 |
CalledNBR: | 17 | | OK | 17 |
LOC: | 34 | * | WARNING | 34 |
metrics are OK
query_band(Begins at: 260, Ends at:345)
Complexity: | 15 | | OK | 15 |
ParamNBR: | 5 | | OK | 5 |
CalledNBR: | 21 | | OK | 21 |
LOC: | 86 | | OK | 86 |
metrics are OK
setup_window(Begins at: 186, Ends at:232)
Complexity: | 3 | ** | BABY-MONSTER | 3 |
LOC: | 47 | ** | BABY-MONSTER | 47 |
metrics are OK
update_default_window(Begins at: 234, Ends at:258)
Complexity: | 1 | ** | BABY-MONSTER | 1 |
ParamNBR: | 1 | * | WARNING | 1 |
LOC: | 25 | * | WARNING | 25 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 12:05:57 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
