[GRASS-QA] GRASS QA: martinl |vedit.h cats.c select.c | 6 clones | 0
monsters |0 warnings
soccerlab.info at gmail.com
Fri Sep 5 12:04:49 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/include/vedit.h
The system don't find class, method and function
in this file during analysis!
File :grass/branches/develbranch_6/lib/vector/vedit/cats.c
Function
Vedit_modify_cats(Begins at: 32, Ends at:101)
| New Metrics |Old Metrics|
Complexity: | 11 | * | WARNING | 11 |
ParamNBR: | 5 | * | WARNING | 5 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 70 | * | WARNING | 70 |
Conclusion: | this function is a WARNING |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/vedit/cats.c clones of Vedit_modify_cats are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/vedit/cats.c Vedit_modify_cats
File :grass/branches/develbranch_6/lib/vector/vedit/select.c
Function
merge_lists(Begins at: 247, Ends at:265)
Complexity: | 3 | | OK | 3 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 19 | | OK | 19 |
Conclusion: | this function is a OK |
metrics are OK
select_by_query(Begins at: 134, Ends at:237)
Complexity: | 18 | ** | BABY-MONSTER | 18 |
ParamNBR: | 7 | ** | BABY-MONSTER | 7 |
CalledNBR: | 23 | ** | BABY-MONSTER | 23 |
LOC: | 104 | ** | BABY-MONSTER | 104 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
Vedit_select_by_query(Begins at: 43, Ends at:125)
Complexity: | 16 | ** | BABY-MONSTER | 16 |
ParamNBR: | 6 | ** | BABY-MONSTER | 6 |
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 83 | * | WARNING | 83 |
metrics are OK
Clone analysis:
This file has 5 potentially cloned functions:
merge_lists merge_lists select_by_query Vedit_select_by_query
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/vedit/select.c clones of merge_lists are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/vector/v.edit/select.c merge_lists
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/vedit/select.c merge_lists
/var/project-manager/grass/grassSVN/grass/trunk/vector/v.edit/select.c merge_lists
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/vedit/select.c clones of select_by_query are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/vedit/select.c select_by_query
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/vedit/select.c clones of Vedit_select_by_query are:
/var/project-manager/grass/grassSVN/grass/trunk/lib/vector/vedit/select.c Vedit_select_by_query
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 12:10:11 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
