[GRASS-QA] GRASS QA: glynn |apply.c execute.c filter.h getfilt.c ...| 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 12:20:06 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/raster/r.mfilter/apply.c
          Function
apply_filter(Begins at: 9, Ends at:54)
              |          New Metrics           |Old Metrics|
Complexity:   |      10 |     * |      WARNING |        10 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |      46 |     * |      WARNING |        46 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/raster/r.mfilter/execute.c
          Function
execute_filter(Begins at: 6, Ends at:121)
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       4 |     * |      WARNING |         4 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |     116 |    ** | BABY-MONSTER |       116 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mfilter/filter.h
The system don't find class, method and function
 in this file during analysis!
          File :grass/trunk/raster/r.mfilter/getfilt.c
          Function
get_filter(Begins at: 6, Ends at:160)
Complexity:   |      33 |   *** |      MONSTER |        33 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      58 |   *** |      MONSTER |        58 |
LOC:          |     155 |   *** |      MONSTER |       155 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mfilter/getrow.c
          Function
getmaprow(Begins at: 9, Ends at:14)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |       6 |       |           OK |         6 |
metrics are OK
getrow(Begins at: 16, Ends at:25)
Complexity:   |       3 |       |           OK |         3 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      10 |       |           OK |        10 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mfilter/glob.h
          File :grass/trunk/raster/r.mfilter/local_proto.h
          File :grass/trunk/raster/r.mfilter/main.c
          Function
main(Begins at: 32, Ends at:140)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      32 |    ** | BABY-MONSTER |        32 |
LOC:          |     109 |    ** | BABY-MONSTER |       109 |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mfilter/main.c clones of main are:
          /var/project-manager/grass/grassSVN/grass/trunk/raster/r.mfilter.fp/main.c  main
          File :grass/trunk/raster/r.mfilter/perform.c
          Function
perform_filter(Begins at: 9, Ends at:103)
Complexity:   |      14 |    ** | BABY-MONSTER |        14 |
ParamNBR:     |       6 |    ** | BABY-MONSTER |         6 |
CalledNBR:    |      36 |    ** | BABY-MONSTER |        36 |
LOC:          |      95 |    ** | BABY-MONSTER |        95 |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mfilter/uppercase.c
          Function
uppercase(Begins at: 1, Ends at:8)
ParamNBR:     |       1 |       |           OK |         1 |
LOC:          |       8 |       |           OK |         8 |
Conclusion:   | this function is a            OK           |
metrics are OK
Clone analysis:
          File :grass/trunk/raster/r.mfilter.fp/apply.c
          File :grass/trunk/raster/r.mfilter.fp/execute.c
          File :grass/trunk/raster/r.mfilter.fp/filter.h
          File :grass/trunk/raster/r.mfilter.fp/getfilt.c
          File :grass/trunk/raster/r.mfilter.fp/getrow.c
          File :grass/trunk/raster/r.mfilter.fp/glob.h
          File :grass/trunk/raster/r.mfilter.fp/local_proto.h
          File :grass/trunk/raster/r.mfilter.fp/main.c
          File :grass/trunk/raster/r.mfilter.fp/perform.c
          File :grass/trunk/raster/r.mfilter.fp/uppercase.c
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 12:25:28 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
