[GRASS-QA] GRASS QA: martinl |open.c | 9 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 5 13:44:27 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/branches/develbranch_6/lib/vector/Vlib/open.c
          Function
fatal_error(Begins at: 59, Ends at:71)
              |          New Metrics           |Old Metrics|
Complexity:   |       5 |       |           OK |         5 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |       2 |       |           OK |         2 |
LOC:          |      13 |       |           OK |        13 |
Conclusion:   | this function is a            OK           |
metrics are OK
format(Begins at: 38, Ends at:42)
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       0 |       |           OK |         0 |
LOC:          |       5 |       |           OK |         5 |
metrics are OK
open_old_dummy(Begins at: 32, Ends at:35)
CalledNBR:    |       0 |       |           OK |         0 |
LOC:          |       4 |       |           OK |         4 |
metrics are OK
Vect_coor_info(Begins at: 611, Ends at:649)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |      11 |     * |      WARNING |        11 |
LOC:          |      39 |       |           OK |        39 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
Vect_maptype_info(Begins at: 659, Ends at:676)
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |      18 |       |           OK |        18 |
metrics are OK
Vect_open_new(Begins at: 517, Ends at:600)
Complexity:   |       8 |     * |      WARNING |         8 |
ParamNBR:     |       3 |     * |      WARNING |         3 |
CalledNBR:    |      43 |   *** |      MONSTER |        43 |
LOC:          |      84 |     * |      WARNING |        84 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
Vect_open_old(Begins at: 413, Ends at:416)
CalledNBR:    |       1 |       |           OK |         1 |
metrics are OK
Vect_open_old_head(Begins at: 467, Ends at:471)
metrics are OK
Vect_open_spatial_index(Begins at: 771, Ends at:836)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       8 |       |           OK |         8 |
LOC:          |      66 |     * |      WARNING |        66 |
metrics are OK
Vect_open_topo(Begins at: 689, Ends at:761)
Complexity:   |       7 |     * |      WARNING |         7 |
CalledNBR:    |      16 |     * |      WARNING |        16 |
LOC:          |      73 |     * |      WARNING |        73 |
metrics are OK
Vect_open_update(Begins at: 430, Ends at:452)
LOC:          |      23 |       |           OK |        23 |
metrics are OK
Vect_open_update_head(Begins at: 485, Ends at:505)
LOC:          |      21 |       |           OK |        21 |
metrics are OK
Vect_set_open_level(Begins at: 96, Ends at:107)
LOC:          |      12 |       |           OK |        12 |
metrics are OK
Vect__open_old(Begins at: 124, Ends at:399)
Complexity:   |      31 |   *** |      MONSTER |        31 |
ParamNBR:     |       5 |     * |      WARNING |         5 |
CalledNBR:    |     102 |   *** |      MONSTER |       102 |
LOC:          |     276 |   *** |      MONSTER |       276 |
metrics are OK
Clone analysis:
This file has 9 potentially cloned functions:
  Vect_coor_info  Vect_maptype_info  Vect_open_new  Vect_open_spatial_index  Vect_open_topo  Vect_open_update  Vect_open_update_head  Vect_set_open_level
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/open.c clones of fatal_error are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  fatal_error
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/open.c clones of Vect_coor_info are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_coor_info
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/open.c clones of Vect_maptype_info are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_maptype_info
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/open.c clones of Vect_open_new are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_open_new
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/open.c clones of Vect_open_spatial_index are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_open_spatial_index
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/open.c clones of Vect_open_topo are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_open_topo
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/open.c clones of Vect_open_update are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_open_update
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/open.c clones of Vect_open_update_head are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_open_update_head
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/open.c clones of Vect_set_open_level are:
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/open.c  Vect_set_open_level
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 13:49:50 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
