[GRASS-QA] GRASS QA: hamish |main.c | 9 clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Fri Sep 5 14:28:23 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/branches/develbranch_6/raster/r.in.bin/main.c
Function
main(Begins at: 72, Ends at:597)
| New Metrics |Old Metrics|
Complexity: | 74 | *** | MONSTER | 74 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 184 | *** | MONSTER | 184 |
LOC: | 526 | *** | MONSTER | 526 |
Conclusion: | this function is a MONSTER |
metrics are OK
SwabDouble(Begins at: 53, Ends at:70)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 18 | | OK | 18 |
Conclusion: | this function is a OK |
metrics are OK
SwabFloat(Begins at: 48, Ends at:51)
CalledNBR: | 1 | | OK | 1 |
LOC: | 4 | | OK | 4 |
metrics are OK
SwabLong(Begins at: 35, Ends at:46)
LOC: | 12 | | OK | 12 |
metrics are OK
SwabShort(Begins at: 25, Ends at:33)
LOC: | 9 | | OK | 9 |
metrics are OK
Clone analysis:
This file has 9 potentially cloned functions:
SwabDouble SwabDouble SwabDouble SwabLong TIFFSwabLong SwabLong SwabLong TIFFSwabLong
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.bin/main.c clones of main are:
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.bin/main.c main
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.bin/main.c clones of SwabDouble are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.mat/main.c SwabDouble
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.bin/main.c SwabDouble
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.mat/main.c SwabDouble
In /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.bin/main.c clones of SwabLong are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.in.mat/main.c SwabLong
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/raster/r.out.bin/tif_swab.c TIFFSwabLong
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.bin/main.c SwabLong
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.in.mat/main.c SwabLong
/var/project-manager/grass/grassSVN/grass/trunk/raster/r.out.bin/tif_swab.c TIFFSwabLong
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 14:33:46 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
