[GRASS-QA] GRASS QA: glynn |Graph.c Graph_set.c Graph_set.c | 7
clones | 0 monsters |0 warnings
soccerlab.info at gmail.com
Fri Sep 5 15:00:28 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/lib/cairodriver/Graph.c
Function
Cairo_Graph_close(Begins at: 236, Ends at:250)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 4 | | OK | 4 |
LOC: | 15 | | OK | 15 |
Conclusion: | this function is a OK |
metrics are OK
Cairo_Graph_set(Begins at: 195, Ends at:234)
Complexity: | 5 | | OK | 5 |
CalledNBR: | 16 | * | WARNING | 16 |
LOC: | 40 | | OK | 40 |
Conclusion: | this function is a WARNING |
metrics are OK
ends_with(Begins at: 298, Ends at:305)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 5 | | OK | 5 |
LOC: | 8 | | OK | 8 |
metrics are OK
init_cairo(Begins at: 252, Ends at:295)
Complexity: | 10 | * | WARNING | 10 |
CalledNBR: | 9 | | OK | 9 |
LOC: | 44 | * | WARNING | 44 |
metrics are OK
init_file(Begins at: 100, Ends at:193)
Complexity: | 20 | ** | BABY-MONSTER | 20 |
CalledNBR: | 25 | ** | BABY-MONSTER | 25 |
LOC: | 94 | ** | BABY-MONSTER | 94 |
Conclusion: | this function is a BABY-MONSTER |
metrics are OK
init_xlib(Begins at: 45, Ends at:97)
Complexity: | 7 | * | WARNING | 7 |
LOC: | 53 | * | WARNING | 53 |
metrics are OK
map_file(Begins at: 307, Ends at:333)
Complexity: | 4 | | OK | 4 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 27 | | OK | 27 |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
init_file init_xlib map_file
In /var/project-manager/grass/grassSVN/grass/trunk/lib/cairodriver/Graph.c clones of Cairo_Graph_close are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/cairodriver/Graph.c Cairo_Graph_close
In /var/project-manager/grass/grassSVN/grass/trunk/lib/cairodriver/Graph.c clones of init_file are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/cairodriver/Graph.c init_file
In /var/project-manager/grass/grassSVN/grass/trunk/lib/cairodriver/Graph.c clones of init_xlib are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/cairodriver/Graph.c init_xlib
In /var/project-manager/grass/grassSVN/grass/trunk/lib/cairodriver/Graph.c clones of map_file are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/cairodriver/Graph.c map_file
File :grass/trunk/lib/pngdriver/Graph_set.c
Function
map_file(Begins at: 41, Ends at:64)
LOC: | 24 | | OK | 24 |
metrics are OK
PNG_Graph_set(Begins at: 66, Ends at:156)
Complexity: | 12 | * | WARNING | 12 |
CalledNBR: | 31 | ** | BABY-MONSTER | 31 |
LOC: | 91 | ** | BABY-MONSTER | 91 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
File :grass/trunk/lib/psdriver/Graph_set.c
Class
paper(Begins at: 33, Ends at:38)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
|OLD Metrics | 1 | 0 | 0 | 0 | 0 | 0 |
Function
get_paper(Begins at: 127, Ends at:170)
CalledNBR: | 13 | * | WARNING | 13 |
metrics are OK
in2pt(Begins at: 114, Ends at:117)
Complexity: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
metrics are OK
output(Begins at: 224, Ends at:231)
CalledNBR: | 3 | | OK | 3 |
metrics are OK
PS_Graph_set(Begins at: 172, Ends at:222)
CalledNBR: | 21 | * | WARNING | 21 |
LOC: | 51 | * | WARNING | 51 |
metrics are OK
swap(Begins at: 119, Ends at:125)
LOC: | 7 | | OK | 7 |
metrics are OK
write_prolog(Begins at: 53, Ends at:95)
LOC: | 43 | * | WARNING | 43 |
metrics are OK
write_setup(Begins at: 97, Ends at:112)
LOC: | 16 | | OK | 16 |
metrics are OK
Clone analysis:
This file has 3 potentially cloned functions:
write_prolog write_setup
In /var/project-manager/grass/grassSVN/grass/trunk/lib/psdriver/Graph_set.c clones of get_paper are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/psdriver/Graph_set.c get_paper
In /var/project-manager/grass/grassSVN/grass/trunk/lib/psdriver/Graph_set.c clones of write_prolog are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/psdriver/Graph_set.c write_prolog
In /var/project-manager/grass/grassSVN/grass/trunk/lib/psdriver/Graph_set.c clones of write_setup are:
/var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/psdriver/Graph_set.c write_setup
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 15:05:51 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
