[GRASS-QA] GRASS QA: martinl |cats.cpp | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Fri Sep 5 18:28:19 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/gui/wxpython/vdigit/cats.cpp
Class
Digit(Begins at: -9999, Ends at:-9999)
| DIT | NOC | WMC | RFC | CBO | LCOM |
|NEW Metrics | 1 | 0 | 37 | 113 | 0 | 21 |
|OLD Metrics | 1 | 0 | 37 | 113 | 0 | 21 |
Method
CopyCats(Begins at: 293, Ends at:298)
| New Metrics |Old Metrics|
Complexity: | 1 | | OK | 1 |
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 6 | | OK | 6 |
Conclusion: | this function is a OK |
metrics are OK
GetCategory(Begins at: 90, Ends at:98)
Complexity: | 2 | | OK | 2 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 9 | | OK | 9 |
metrics are OK
GetLayers(Begins at: 134, Ends at:144)
ParamNBR: | 0 | | OK | 0 |
LOC: | 11 | | OK | 11 |
metrics are OK
GetLineCats(Begins at: 153, Ends at:202)
Complexity: | 9 | * | WARNING | 9 |
CalledNBR: | 8 | | OK | 8 |
LOC: | 50 | * | WARNING | 50 |
Conclusion: | this function is a WARNING |
metrics are OK
InitCats(Begins at: 26, Ends at:80)
Complexity: | 11 | * | WARNING | 11 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 55 | * | WARNING | 55 |
metrics are OK
SetCategory(Begins at: 109, Ends at:125)
LOC: | 17 | | OK | 17 |
metrics are OK
SetLineCats(Begins at: 215, Ends at:282)
Complexity: | 10 | * | WARNING | 10 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 19 | * | WARNING | 19 |
LOC: | 68 | * | WARNING | 68 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 05 18:33:44 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
