[GRASS-QA] GRASS QA: martinl |driver.c | no clones | 0 monsters |0
warnings
soccerlab.info at gmail.com
Tue Sep 9 10:48:05 EDT 2008
Hello martinl,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
File :grass/trunk/vector/v.digit/driver.c
Function
convert(Begins at: 25, Ends at:35)
| New Metrics |Old Metrics|
Complexity: | 3 | | OK | 3 |
ParamNBR: | 4 | * | WARNING | 4 |
CalledNBR: | 7 | | OK | 7 |
LOC: | 11 | | OK | 11 |
Conclusion: | this function is a WARNING |
metrics are OK
driver_close(Begins at: 136, Ends at:139)
Complexity: | 1 | | OK | 1 |
ParamNBR: | 1 | | OK | 1 |
CalledNBR: | 0 | | OK | 0 |
LOC: | 4 | | OK | 4 |
Conclusion: | this function is a OK |
metrics are OK
driver_cont(Begins at: 37, Ends at:51)
ParamNBR: | 2 | | OK | 2 |
CalledNBR: | 3 | | OK | 3 |
LOC: | 15 | | OK | 15 |
metrics are OK
driver_line_width(Begins at: 17, Ends at:20)
metrics are OK
driver_move(Begins at: 53, Ends at:62)
CalledNBR: | 1 | | OK | 1 |
LOC: | 10 | | OK | 10 |
metrics are OK
driver_open(Begins at: 116, Ends at:134)
Complexity: | 2 | | OK | 2 |
CalledNBR: | 13 | * | WARNING | 13 |
LOC: | 19 | | OK | 19 |
metrics are OK
driver_plot_icon(Begins at: 64, Ends at:77)
ParamNBR: | 3 | * | WARNING | 3 |
LOC: | 14 | | OK | 14 |
metrics are OK
driver_refresh(Begins at: 110, Ends at:114)
LOC: | 5 | | OK | 5 |
metrics are OK
driver_rgb_color(Begins at: 12, Ends at:15)
metrics are OK
get_window(Begins at: 79, Ends at:91)
CalledNBR: | 4 | | OK | 4 |
LOC: | 13 | | OK | 13 |
metrics are OK
setup(Begins at: 93, Ends at:108)
CalledNBR: | 6 | | OK | 6 |
LOC: | 16 | | OK | 16 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
____________________________________________
Threshold GRASS6 key metrics values at Tue Sep 09 10:54:18 EDT 2008 are:
| warning | middle | extrem |
| limits | limits | limits |
Complexity (Cyclo): | 6 | 13 | 21 |
ParamNBR: | 3 | 6 | 9 |
CalledNBR: | 10 | 23 | 37 |
LOC: | 42 | 91 | 141 |
Measures (see below Web page for details) :
-Complexity (Cyclo): a complexity index
-ParamNBR: number of passed parameters
-CalledNBR: number of called functions
-LOC: Lines Of Code
-Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
OK : Nothing to say at all
* : this is getting close to be out of range, consider revising the code
** : this is a baby monster, you should revise this function
Conclusion interpretation :
CORRECT : if all metrics are situated before warning limits
WARNING : if 1 to more metrics are between warning and middle limits
BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
MONSTERS : if 1 to more metrics are in the extreme limits
Brought to you by :
