[GRASS-QA] GRASS QA: glynn |gisinit.c | 1 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Tue Sep 9 10:52:56 EDT 2008
Hello glynn,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/lib/gis/gisinit.c
          Function
gisinit(Begins at: 114, Ends at:146)
              |          New Metrics           |Old Metrics|
Complexity:   |       1 |       |           OK |         1 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |       3 |       |           OK |         3 |
LOC:          |      33 |       |           OK |        33 |
Conclusion:   | this function is a            OK           |
metrics are OK
G__check_gisinit(Begins at: 104, Ends at:111)
Complexity:   |       2 |       |           OK |         2 |
CalledNBR:    |       4 |       |           OK |         4 |
LOC:          |       8 |       |           OK |         8 |
metrics are OK
G__gisinit(Begins at: 44, Ends at:72)
Complexity:   |       7 |     * |      WARNING |         7 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      12 |     * |      WARNING |        12 |
LOC:          |      29 |       |           OK |        29 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
G__no_gisinit(Begins at: 83, Ends at:94)
Complexity:   |       3 |       |           OK |         3 |
LOC:          |      12 |       |           OK |        12 |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
In /var/project-manager/grass/grassSVN/grass/trunk/lib/gis/gisinit.c clones of G__no_gisinit are:
          /tmp/grassSVN/grass/trunk/lib/gis/gisinit.c  G__no_gisinit
____________________________________________
Threshold GRASS6 key metrics values at Tue Sep 09 10:59:09 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
