[GRASS-QA] GRASS QA: rmatev |dgraph.c e_intersect.c vlib_buffer.c dgraph.c ...| 2 clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Wed Sep 10 12:34:16 EDT 2008
Hello rmatev,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass-addons/vector/v.buffer2/dgraph.c
The system don't find class, method and function
 in this file during analysis!
          File :grass-addons/vector/v.buffer2/e_intersect.c
          File :grass-addons/vector/v.buffer2/vlib_buffer.c
          File :grass-addons/vector/v.parallel2/dgraph.c
          Class
intersection_point(Begins at: 280, Ends at:284)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
          Class
seg_intersection(Begins at: 286, Ends at:290)
          Class
seg_intersection_list(Begins at: 292, Ends at:296)
          Class
seg_intersections(Begins at: 298, Ends at:305)
          Function
add_ipoint(Begins at: 356, Ends at:376)
              |          New Metrics           |Old Metrics|
Complexity:   |       3 |   *** |      MONSTER |         3 |
ParamNBR:     |       6 |   *** |      MONSTER |         6 |
CalledNBR:    |       7 |   *** |      MONSTER |         7 |
LOC:          |      21 |   *** |      MONSTER |        21 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
add_ipoint1(Begins at: 339, Ends at:353)
Complexity:   |       2 |   *** |      MONSTER |         2 |
ParamNBR:     |       4 |   *** |      MONSTER |         4 |
CalledNBR:    |       2 |   *** |      MONSTER |         2 |
LOC:          |      15 |   *** |      MONSTER |        15 |
metrics are OK
compare(Begins at: 403, Ends at:415)
ParamNBR:     |       2 |   *** |      MONSTER |         2 |
CalledNBR:    |       0 |   *** |      MONSTER |         0 |
LOC:          |      13 |   *** |      MONSTER |        13 |
metrics are OK
create_si_struct(Begins at: 307, Ends at:324)
ParamNBR:     |       1 |   *** |      MONSTER |         1 |
CalledNBR:    |       6 |   *** |      MONSTER |         6 |
LOC:          |      18 |   *** |      MONSTER |        18 |
metrics are OK
destroy_si_struct(Begins at: 326, Ends at:336)
CalledNBR:    |       4 |   *** |      MONSTER |         4 |
LOC:          |      11 |   *** |      MONSTER |        11 |
metrics are OK
find_all_intersections(Begins at: 418, Ends at:522)
Complexity:   |      18 |   *** |      MONSTER |        18 |
CalledNBR:    |      32 |   *** |      MONSTER |        32 |
LOC:          |     105 |   *** |      MONSTER |       105 |
metrics are OK
pg_addedge(Begins at: 585, Ends at:613)
Complexity:   |       4 |   *** |      MONSTER |         4 |
ParamNBR:     |       3 |   *** |      MONSTER |         3 |
LOC:          |      29 |   *** |      MONSTER |        29 |
metrics are OK
pg_addedge1(Begins at: 576, Ends at:583)
LOC:          |       8 |   *** |      MONSTER |         8 |
metrics are OK
pg_create(Begins at: 615, Ends at:688)
Complexity:   |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      10 |   *** |      MONSTER |        10 |
LOC:          |      74 |   *** |      MONSTER |        74 |
metrics are OK
pg_create_struct(Begins at: 526, Ends at:540)
Complexity:   |       1 |   *** |      MONSTER |         1 |
metrics are OK
pg_destroy_struct(Begins at: 542, Ends at:552)
CalledNBR:    |       5 |   *** |      MONSTER |         5 |
metrics are OK
pg_existsedge(Begins at: 555, Ends at:573)
LOC:          |      19 |   *** |      MONSTER |        19 |
metrics are OK
segment_intersection_2d(Begins at: 20, Ends at:278)
Complexity:   |      40 |   *** |      MONSTER |        40 |
ParamNBR:     |      13 |   *** |      MONSTER |        13 |
CalledNBR:    |      70 |   *** |      MONSTER |        70 |
LOC:          |     259 |   *** |      MONSTER |       259 |
metrics are OK
sort_intersection_list(Begins at: 378, Ends at:401)
Complexity:   |       5 |   *** |      MONSTER |         5 |
LOC:          |      24 |   *** |      MONSTER |        24 |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass-addons/vector/v.parallel2/e_intersect.c
          File :grass-addons/vector/v.parallel2/vlib_buffer.c
          Function
add_line_to_array(Begins at: 687, Ends at:695)
ParamNBR:     |       5 |   *** |      MONSTER |         5 |
LOC:          |       9 |   *** |      MONSTER |         9 |
metrics are OK
angular_tolerance(Begins at: 127, Ends at:135)
CalledNBR:    |       3 |   *** |      MONSTER |         3 |
metrics are OK
convolution_line(Begins at: 297, Ends at:425)
Complexity:   |      16 |   *** |      MONSTER |        16 |
ParamNBR:     |       9 |   *** |      MONSTER |         9 |
CalledNBR:    |      30 |   *** |      MONSTER |        30 |
LOC:          |     129 |   *** |      MONSTER |       129 |
metrics are OK
elliptic_tangent(Begins at: 77, Ends at:92)
ParamNBR:     |       7 |   *** |      MONSTER |         7 |
LOC:          |      16 |   *** |      MONSTER |        16 |
metrics are OK
elliptic_transform(Begins at: 52, Ends at:69)
metrics are OK
extract_contour(Begins at: 432, Ends at:528)
Complexity:   |      12 |   *** |      MONSTER |        12 |
CalledNBR:    |       9 |   *** |      MONSTER |         9 |
LOC:          |      97 |   *** |      MONSTER |        97 |
metrics are OK
extract_inner_contour(Begins at: 588, Ends at:615)
LOC:          |      28 |   *** |      MONSTER |        28 |
metrics are OK
extract_outer_contour(Begins at: 540, Ends at:579)
Complexity:   |       6 |   *** |      MONSTER |         6 |
LOC:          |      40 |   *** |      MONSTER |        40 |
metrics are OK
line_coefficients(Begins at: 98, Ends at:103)
LOC:          |       6 |   *** |      MONSTER |         6 |
metrics are OK
line_intersection(Begins at: 110, Ends at:125)
ParamNBR:     |       8 |   *** |      MONSTER |         8 |
metrics are OK
norm_vector(Begins at: 27, Ends at:40)
CalledNBR:    |       1 |   *** |      MONSTER |         1 |
LOC:          |      14 |   *** |      MONSTER |        14 |
metrics are OK
parallel_line(Begins at: 149, Ends at:294)
Complexity:   |      20 |   *** |      MONSTER |        20 |
ParamNBR:     |      10 |   *** |      MONSTER |        10 |
LOC:          |     146 |   *** |      MONSTER |       146 |
metrics are OK
parallel_line_b(Begins at: 697, Ends at:794)
CalledNBR:    |      35 |   *** |      MONSTER |        35 |
LOC:          |      98 |   *** |      MONSTER |        98 |
metrics are OK
point_in_buf(Begins at: 622, Ends at:684)
Complexity:   |       7 |   *** |      MONSTER |         7 |
LOC:          |      63 |   *** |      MONSTER |        63 |
metrics are OK
rotate_vector(Begins at: 42, Ends at:46)
LOC:          |       5 |   *** |      MONSTER |         5 |
metrics are OK
Vect_line_buffer(Begins at: 830, Ends at:926)
Complexity:   |      10 |   *** |      MONSTER |        10 |
CalledNBR:    |      26 |   *** |      MONSTER |        26 |
metrics are OK
Vect_line_parallel2(Begins at: 806, Ends at:817)
LOC:          |      12 |   *** |      MONSTER |        12 |
metrics are OK
Clone analysis:
This file has 2 potentially cloned functions:
  vect
In /var/project-manager/grass/grassSVN/grass-addons/vector/v.parallel2/vlib_buffer.c clones of norm_vector are:
          /var/project-manager/grass/grassSVN/grass/branches/develbranch_6/lib/vector/Vlib/buffer.c  vect
          /var/project-manager/grass/grassSVN/grass/trunk/lib/vector/Vlib/buffer.c  vect
____________________________________________
Threshold GRASS6 key metrics values at Wed Sep 10 12:40:43 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         0 |         0 |         0 |
ParamNBR:             |         0 |         0 |         0 |
CalledNBR:            |         0 |         0 |         0 |
LOC:                  |         0 |         0 |         0 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
