[GRASS-QA] GRASS QA: hamish |do_vectors.c r_vlines.c vector.h | no clones | 0 monsters |0 warnings
soccerlab.info at gmail.com soccerlab.info at gmail.com
Fri Sep 19 09:04:56 EDT 2008
Hello hamish,
here's a report on your recent GRASS-SVN change :
ANALYSIS
your changes to files/class/methods/functions :
          File :grass/trunk/ps/ps.map/do_vectors.c
          Function
do_vectors(Begins at: 19, Ends at:116)
              |          New Metrics           |Old Metrics|
Complexity:   |      18 |    ** | BABY-MONSTER |        18 |
ParamNBR:     |       1 |       |           OK |         1 |
CalledNBR:    |      30 |    ** | BABY-MONSTER |        30 |
LOC:          |      98 |    ** | BABY-MONSTER |        98 |
Conclusion:   | this function is a  BABY-MONSTER           |
metrics are OK
do_vpoints(Begins at: 119, Ends at:156)
Complexity:   |       6 |     * |      WARNING |         6 |
CalledNBR:    |       9 |       |           OK |         9 |
LOC:          |      38 |       |           OK |        38 |
Conclusion:   | this function is a       WARNING           |
metrics are OK
Clone analysis:
This file does not contain cloned functions
          File :grass/trunk/ps/ps.map/r_vlines.c
          Function
read_vlines(Begins at: 39, Ends at:287)
Complexity:   |      46 |   *** |      MONSTER |        46 |
ParamNBR:     |       2 |       |           OK |         2 |
CalledNBR:    |      65 |   *** |      MONSTER |        65 |
LOC:          |     249 |   *** |      MONSTER |       249 |
Conclusion:   | this function is a       MONSTER           |
metrics are OK
Clone analysis:
          File :grass/trunk/ps/ps.map/vector.h
          Class
vector(Begins at: 88, Ends at:100)
             |    DIT |    NOC |    WMC |    RFC |    CBO |   LCOM |
|NEW Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
|OLD Metrics |      1 |      0 |      0 |      0 |      0 |      0 |
Clone analysis:
____________________________________________
Threshold GRASS6 key metrics values at Fri Sep 19 09:13:18 EDT 2008 are:
                      | warning   | middle    | extrem    |
                      | limits    | limits    | limits    |
Complexity (Cyclo):   |         6 |        13 |        21 |
ParamNBR:             |         3 |         6 |         9 |
CalledNBR:            |        10 |        23 |        37 |
LOC:                  |        42 |        91 |       141 |
Please visite our web site on your project at :http://web.soccerlab.polymtl.ca/project-manager/index.html
Measures (see below Web page for details) :
    -Complexity (Cyclo): a complexity index
    -ParamNBR: number of passed parameters
    -CalledNBR: number of called functions
    -LOC: Lines Of Code
    -Global analysis: based on 21 metrics(the fourth preceding include)
Message interpretation :
    OK : Nothing to say at all
    *  : this is getting close to be out of range, consider revising the code
    ** : this is a baby monster, you should revise this function
Conclusion interpretation :
    CORRECT     : if all metrics are situated before warning limits
    WARNING     : if 1 to more metrics are between warning and middle limits
    BABY_MONSTER: if 1 to more metrics are between middle and extreme limits
    MONSTERS    : if 1 to more metrics are in the extreme limits
Brought to you by :
